raunakbardia |
February 22, 2019 11:45 |
Problem with Diffusion Equation Implementation
2 Attachment(s)
Hi all,
I am using OpenFOAM v1706 and trying to make some additions to the interFlow solver.
I have initialized a field that is concentrated at the interfacial cells of my two-phase system. It is shown by the attached image (InitialCondition.jpg). I use a simple diffusion equation to diffuse this field on the rest of the grid. The result is shown in the second image (Diffused.jpg). Clearly, the circular symmetry is lost and it has to be due to some error in my implementation of the diffusion equation. But the volume integration of the initial source is conserved to the tolerance level that was specified.
Here is my source code used for the diffusion equation
spreadSource.H
const dimensionedScalar mdotDiffusionConstant("diff",dimArea,dict_.lookupOrDefault<scalar>("mdotDiffusionConstant",1000));
mdot1 = mdot0; // mdot0 stores the initial condition
fvScalarMatrix mdotSpreadEqn
fvm::laplacian(mdotDiffusionConstant, mdot1)
mdotSpreadEqn.solve();
The mdot fields were created as follows.
createFields.H
// Calculating Source Term at Interfacial Cells
volScalarField mdot0
IOobject
"mdot0",
runTime.timeName(),
mesh,
IOobject::NO_READ,
IOobject::AUTO_WRITE
mesh,
dimensionedScalar("zero",dimensionSet(1,-3,-1,0,0,0,0),0.0)
// Distributing Source Term in the domain
volScalarField mdot1
IOobject
"mdot1",
runTime.timeName(),
mesh,
IOobject::NO_READ,
mesh,
dimensionedScalar("zero",dimensionSet(1,-3,-1,0,0,0,0),0.0),
mdotBoundaries
Here is the fvSolution file I am using:
fvSolution
solvers
"alpha.water.*"
interfaceMethod "isoAdvector";
isoFaceTol 1e-8;
surfCellTol 1e-8;
snapAlphaTol 1e-8;
nAlphaBounds 3;
clip true;
writeIsoFaces false;
writeInterfaceDetails true;
phaseChange true;
prescribedmdot true;
massfluxvalue -100.0;
nAlphaCorr 2;
nAlphaSubCycles 1;
cAlpha 1;
MULESCorr yes;
nLimiterIter 3;
solver smoothSolver;
smoother symGaussSeidel;
tolerance 1e-8;
relTol 0;
mdotDiffusionConstant 6.25e-08;
pcorr
solver PCG;
preconditioner DIC;
tolerance 1e-10;
relTol 0;
p_rgh
solver PCG;
preconditioner DIC;
tolerance 1e-07;
relTol 0.05;
p_rghFinal
$p_rgh;
tolerance 1e-07;
relTol 0;
mdot1
solver PCG;
preconditioner DIC;
tolerance 1e-8;
relTol 0.1;
mdot1Final
$mdot1;
U
solver PBiCG;
preconditioner DILU;
tolerance 1e-06;
relTol 0;
PIMPLE
momentumPredictor no;
nCorrectors -1;
nNonOrthogonalCorrectors -1;
nAlphaCorr 1;
nAlphaSubCycles 1;
cAlpha 1;
pRefCell 0;
pRefValue 0;
SIMPLE
nNonOrthogonalCorrectors 0;
I believe that implementation of a Diffusion equation should be straightforward in OpenFOAM. Any help will be much appreciated.
Thanks.
