[Sponsors] | |||||
A Pedrioli
Rep Power: 9 ![]() |
Hello!
I'm trying to run some simulations with some rough surfaces but unfortunately I don't see any effect, i.e. the solution doesn't change if I vary the Ks number. Here an example in how I set the BC for nut: PHP Code:
Thank you in advance! |
Robert
Rep Power: 13 ![]() |
A few ideas without knowing the exact solution.
- The wallfunction seems to be best suited for flows with a large inherent nut value. I tried differen Ks values in a lamiar flow with the average nut being < 1e-10 and there are no visible changes. - How does Ks = 0.2 relate to your geometry? If your airfoil is tenth of meters long, Ks = 0.2 might not do much. You could try to use a much larger value. - I tested the wallfunction with the channel395 case and Ks = 1. Graphically, in paraview, there were no visible changes, but plotting nut and U over the distance from the wall showed minimal changes.
If you liked my answer to your question, please consider leaving a "Like" in return
A Pedrioli
No the airfoil is only 1 meter long. Now I tried for greater Ks but seems to be always a little variation. Could be a problem of meshing? Or is it beacause it's in 2D?
For surface roughness problem the only thing that I have to change is the BC at wall in 0/nut right? Thank you! |
Robert
Meshing, that might be it. The BC does not work if ks is larger than your first cell height.
A Pedrioli
In fact, adjusting the first cell height I get some results that makes sense. Thank you. Now I had some difficulties to get the right drag coefficient. Do you have any advice?? Finer mesh behind the airfoil?
| Thread Tools | Search this Thread |
| Display Modes | |
| Thread | Thread Starter | Forum | Replies | Last Post |
| [Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 12:04 |
| What's the problem with turbulence models near the wall region? | Jaydi_21 | Main CFD Forum | 6 | July 7, 2017 03:39 |
| Running UDF with Supercomputer | roi247 | FLUENT | 4 | October 15, 2015 14:41 |
| ParaView for OF-1.6-ext | Chrisi1984 | OpenFOAM Installation | 0 | December 31, 2010 07:42 |
| Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug | unoder | OpenFOAM Installation | 11 | January 30, 2008 21:30 |
