shima
Rep Power: 9 ![]() |
Hi all,
I am running a simulation with olafoam solver, I want to run in parallel but I can't although it works when I run it with one processor. I did put decomposeParDict in system folder: FoamFile { version 2.0; format ascii; class dictionary; location "system"; object decomposeParDict; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // numberOfSubdomains 32; method hierarchical; hierarchicalCoeffs { n ( 4 2 4 ); delta 0.001; order xyz; } I want to use 2 nodes with 16 processors each, I want to check the order of the commands that I am using to see whether I make mistake while writing commands. These are the commands that I am using: blockMesh decomposePar mpirun -np 32 setFields -parallel mpirun -np 32 olaFlow -parallel I will appreciate for any help. Thanks, Shima. |
Andrew Coughtrie
Rep Power: 16 ![]() |
Hi Shima,
What are the errors when you run your commands, are you running on a system which uses a job scheduler. Andrew |
#3 | |
shima
decomposePar mpirun --bind-to-core blockMesh -parallel > err0 mpirun --bind-to-core setFields -parallel > err1 mpirun --bind-to-core olaFlow -parallel > err2 Do you think that the problem was for running blockMesh without parallel running.? |
Andrew Coughtrie
To start with blockMesh can't be run in parallel so that isn't the problem. Doing decomposePar before blockMesh won't help, it will either give an error or just decompose the mesh that is already there if you haven't cleaned the case.
If I were you I'd run the following before you submit the job to only run the olaflow command: blockMesh setFields decomposePar Then in your job submission script: mpirun -np 32 olaFlow -parallel See how that goes and post any errors you get. Andrew |
#5 | |
shima
Thanks , now it seems working too, further if I get error I will post it here, |
#6 | |
shima
Hi I used the same method that you have told me and it did work, but now, when I want to draw the water time series, it is wrong. I did reconstruct and writeCellcenter before extracting data, do you know if there is any other thing that I need to do? I believe that the problem is something related to parallel run because when I run with one processor it doesn't looks like that. Best, shima |
Andrew Coughtrie
Sorry but I'm not sure what you mean by the water time series. Why the data is wrong could be due to any number of things.
Possibly try reconstructParMesh before reconstructPar and then the rest. I don't have any other suggestions. Andrew |
shima
I mean water surface elevation var time , Thank you for your hint, I will do that, just one question, should I do reconstructPar -latest time?
#9 |
Andrew Coughtrie
If you're only interested in the latest time and it would otherwise take a long time to reconstruct all the time steps then yes. If you need to analyse the change in data over time you'll need more than just the latest time.
Andrew |
Display Modes | |
[Other] blueCFD-Core-2016 user compiled solvers not running in parallel | sbence | OpenFOAM Installation | 10 | December 5, 2018 08:44 |
Error running openfoam in parallel | fede32 | OpenFOAM Programming & Development | 5 | October 4, 2018 16:38 |
error while running in parallel using openmpi on local mc 6 processors | suryawanshi_nitin | OpenFOAM | 10 | February 22, 2017 21:33 |
Fluent 14.0 file not running in parallel mode in cluster | tejakalva | FLUENT | 0 | February 4, 2015 07:02 |
Problems running in parallel - missing controlDict | Argen | OpenFOAM Running, Solving & CFD | 4 | June 7, 2012 03:50 |
