March 16, 2019, 08:54 |
Turbulence Model switch RKE to K-omega SST
Andrew
Rep Power: 8 |
Hi guys, i would kindly ask some questions.
i'm dealing with a problem of external aerodynamics. In the first try, i've used k omega sst, but it diverges because of the omega bc value. In the second try, i've used RKE, i noticed it converges very rapidly. I would like to understand 3 things: 1) is it normal (in general )that RKE converges faster than k-omega SST? 2) is k-omega SST stability more dependend from bc used with respect to RKE? 3) how could i switch from RKE model to K - omega SST for example after some iterations? Thanks for the time spent to read this post. Astan |
March 29, 2019, 07:56 |
Andrew
Rep Power: 8 |
hi guys, could anyone help me?
March 31, 2019, 04:05 |
Rep Power: 12 |
I think convergence behaviour for RKE and kOmegaSST will be similar for an external aerdynamics problem.
If you can setup the case correctly according to the yPlus kOmegaSST can converge... You can check this thread: One more time: wall functions - SST |
April 6, 2019, 03:54 |
Andrew
Rep Power: 8 |
thanks you for the reply mzzmrt, i found usefull that thread you suggest me!
Only two turbulence options available in CFX Pre | Jack001 | CFX | 5 | March 30, 2016 02:47 |
Flow over a blunt body - SST turbulence model | bharath | CFX | 5 | January 29, 2016 10:16 |
At high Y+ values does the K Omega SST model just behave like the K Epsilon model? | JuPa | CFX | 0 | December 22, 2015 06:44 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
k omega turbulence model | sailspace | OpenFOAM Running, Solving & CFD | 0 | November 12, 2013 05:43 |
