Foam Fatal error running icoFsiFoam
Old   November 15, 2014, 12:47
Default Foam Fatal error running icoFsiFoam
ricardo avila
ricardo1987 is on a distinguished road
Hi everyone,
I am having trouble running icoFsiFoam. I get the following error shown while running it in the fluid directory:
--> FOAM FATAL ERROR:
Cannot find file "points" in directory "constant/solid/polyMesh"
From function Time::findInstance(const fileName&, const word&, const IOobject::readOption)
in file db/Time/findInstance.C at line 148.
FOAM exiting
I have ran blockMesh in both, the solid and the fluid directory. Also ran checkMesh on both resulting in "mesh ok". I have also checked that the points file is in the solid directory as well as in the fluid...
I have not been able to find related information, im kind of lost here... any ideas?
Thanks a lot in advance for your reply,
Ricardo
ricardo1987 is offline   Reply With Quote
Old   November 17, 2014, 13:12
Hao Chen
hchen is on a distinguished road
Did you run make links?
Best regards
Hao
hchen is offline   Reply With Quote
Old   January 18, 2018, 12:05
Sam
anufagbemi is on a distinguished road
Had the same problem. please has anyone been able to solve the problem? All my links are in place.
Thanks
Samuel
anufagbemi is offline   Reply With Quote
Old   March 28, 2019, 13:47
xena
xena is on a distinguished road
hi sam
if you could solve the problem, please tell me what you did, because I'm facing the same issue even though I did all the steps
xena is offline   Reply With Quote
icofsifoam, openfoam, solvers
[blockMesh] error message with modeling a cube with a hold at the center hsingtzu OpenFOAM Meshing & Mesh Conversion 2 March 14, 2012 09:56
[blockMesh] BlockMesh FOAM warning gaottino OpenFOAM Meshing & Mesh Conversion 7 July 19, 2010 14:11
[blockMesh] Axisymmetrical mesh Rasmus Gjesing (Gjesing) OpenFOAM Meshing & Mesh Conversion 10 April 2, 2007 14:00
[Gmsh] Import gmsh msh to Foam adorean OpenFOAM Meshing & Mesh Conversion 24 April 27, 2005 08:19
error while compiling the USER Sub routine CFD user CFX 3 November 25, 2002 15:16
