chtMultiRegionFoam "adjustTimeStep" not adjusting
Old   March 29, 2019, 00:54
Default chtMultiRegionFoam "adjustTimeStep" not adjusting
Adam
Adam_K is on a distinguished road
I am trying to solve a two-phase heat transfer problem with two solid phases (see this figure) using the chtMultiRegionFoam solver. The analytical solution is known and for a thin (200 um) slab the simulation replicates it well with an adjustable timestep with maxDi = 1.
The solver appears to have settled on a time step of about 7 ns, sticking with that time step for the entire simulation of 1 ms. This does not appear logical to me as I would have expected a smaller time step initially and then a larger one as the temperature profile approaches equilibrium.
Is the time step supposed to adjust each time? Or does it just perform one adjustment initially?
Here is a link to the case file on DropBox.
Here is my controlDict file:
|  \\    /   O peration     | Version:  5                                     |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     chtMultiRegionFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         1e-3;
deltaT          1e-7;
writeControl    runTime;
writeInterval   1e-4;
purgeWrite      0;
writeFormat     ascii;
writePrecision  8;
writeCompression off;
timeFormat      general;
timePrecision   8;
runTimeModifiable yes;
adjustTimeStep  yes;
maxDeltaT       1e-5;
maxDi           1;
functions
    #includeFunc  probesMatrix
    #includeFunc  probesFibres
Adam_K is offline   Reply With Quote
Old   March 29, 2019, 08:46
Tobi's Avatar
Tobias Holzmann
Tobi has a spectacular aura aboutTobi has a spectacular aura aboutTobi has a spectacular aura about
Send a message via ICQ to Tobi Send a message via Skype™ to Tobi
Please provide a simple test case to check it.
Keep foaming,
Tobias Holzmann
Tobi is offline   Reply With Quote
Old   March 31, 2019, 03:56
Adam
Thanks for the suggestion, I thought it may have been some syntax issue that I was missing in my controlDict file.
I updated the original post with in image of my system and a link to my case file on DropBox.
OF 6 wallHeatFlux utility not working on chtMultiRegionFoam tutorial troparry OpenFOAM Post-Processing 1 January 10, 2022 07:12
Error in thermophysical properties (chtMultiRegionFoam) mukut OpenFOAM Pre-Processing 28 November 23, 2021 07:34
Simulation of a sample in a furnace w/ chtMultiRegionFoam sergimart7 OpenFOAM Running, Solving & CFD 7 August 12, 2015 07:48
What does this error when use solver chtMultiRegionFoam mean sajad6 OpenFOAM Running, Solving & CFD 7 October 6, 2014 08:38
FOAM FATAL IO ERROR for chtMultiRegionFoam xiaoyoyo OpenFOAM Running, Solving & CFD 0 May 8, 2012 17:49
