April 9, 2019, 12:27 |
chtMultiRegionSimpleFoam Compilation Error
Raza Javed
Rep Power: 6 |
I am trying to run chtMultiRegionSimpleFoam for my problem. I have created it's geometry and mesh in Salome. After that, I imported the UNV file in OpenFoam4 and Meshed it using IdeasUnvToFoam utility. It was successfully completed without errors. My geometry consists of three solid regions. Hot_box, cold_box, and Rod. both these boxes are connected using the Rod between them. And I am trying to simulate the heat transfer from the Hot_box to cold_box. The figure of the mesh and geometry is attached. After modifying the case directories according to my problem, When I run the Allrun command it gives the following error. Code:
Solving for solid region Hot_box --> FOAM FATAL ERROR: cannot be called for a calculatedFvPatchField on patch room of field h in file "/home/openfoam/run/heatTest/0/Hot_box/h" You are probably trying to solve for a field with a default boundary condition. From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = double] in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 187. FOAM aborting I am unable to understand the error. Can someone help me out in this? Thank you heat_transfer.jpg heat_transfer_geom.jpg |
April 9, 2019, 22:31 |
Peter Baskovich
Rep Power: 11 |
Post the rest of your case, 0, system and constant. Mesh should be small enough to post.
April 10, 2019, 03:50 |
Raza Javed
Rep Power: 6 |
Thank you so much for your reply.
I had some mistake in writing the dictionary file for one of my regions in system folder. After rectifying it, the simulation is now running. Now i am doing post-processing in paraview. Thank you |
boundaries condition, chtmultiregionsimplefoam, solver compilation error |
Display Modes | |
[blockMesh] blockMesh with double grading. | spwater | OpenFOAM Meshing & Mesh Conversion | 92 | January 12, 2019 10:00 |
Pressure outlet boundary condition | rolando | OpenFOAM Running, Solving & CFD | 62 | September 18, 2017 07:45 |
DPM udf error | haghshenasfard | FLUENT | 0 | April 13, 2016 07:35 |
[OpenFOAM] Native ParaView Reader Bugs | tj22 | ParaView | 270 | January 4, 2016 12:39 |
Compiling problems with hello worldC | fw407 | OpenFOAM Installation | 21 | January 6, 2008 18:38 |
