(chtMultiRegionFoam) Temperature is not increasing |
Ümit Yelken
Rep Power: 8 ![]() |
Hi guys,
Im using chtMultiRegionFoam with OpenFOAM 2.1.1 . My time step is very small. Its order is about 8e-8 . After simulation worked for 25ms, temperature stays almost same, it is not increasing. When i change co number little bit it works normally and temprature starts to increase. After work for 3-4ms it happens again. When i increase Co number again, it works normally and it happens again and again. Do you have any idea? ![]() This is my fvsolution and fvschemes ddtSchemes { default Euler; } gradSchemes { default Gauss linear; } divSchemes { default none; } laplacianSchemes { default none; laplacian(K,T) Gauss linear limited 0.333; } interpolationSchemes { default linear; } snGradSchemes { default limited 0.333; } fluxRequired { default no; } fvsolution solvers { T { solver PCG; preconditioner DIC; tolerance 1e-06; relTol 0.1; } TFinal { $T; tolerance 1e-06; relTol 0; } } PIMPLE { nNonOrthogonalCorrectors 1; } |
Rep Power: 7 ![]() |
Could you find a solution for your problem?
I have the same issue. |
Praharsha Reddy
Hi PSander. Did you found out the solution. I am facing the same issue
No, unfortunately not.
Display Modes | |
Get access to Temperature at chtMultiRegionFoam | Perschr | OpenFOAM Programming & Development | 1 | June 27, 2017 15:13 |
Strange chtMultiRegionFoam behaviour - temperature drops during heating | petr.f. | OpenFOAM Running, Solving & CFD | 3 | January 24, 2017 07:54 |
Temperature Dependent Thermal conductivity in chtMultiRegionFoam | Mohammad Jam | OpenFOAM Programming & Development | 3 | November 9, 2016 12:50 |
heat transfer coefficient value in floefd | jason kid | FloEFD, FloWorks & FloTHERM | 10 | October 16, 2016 16:55 |
temperature increasing at zero heatflux wall | dokeun | FLUENT | 0 | May 26, 2011 00:33 |
