Add a constraint equation
Like Tree1Likes
  • 1 Post By sebastien.cadalen
Old   July 10, 2013, 08:28
Default Add a constraint equation
sébastien cadalen
sebastien.cadalen is on a distinguished road
Dear all,
This post is about the way to impose an integral relation on the problem variables. As an example, let us consider a steady-state thermal transport problem with the following constraint:
\frac{1}{V} \int_{\mathcal{V}} T \, d\mathcal{V} = T_0
where \mathcal{V} is the fluid domain, V is the volume of the fluid domain, and T_0 a given temperature.
From a mathematical point of view this is equivalent to introduce a constant source term in the domain to satisfy the constraint. If the unconstrain problem is writen in the discrete space A \cdot X = B hence the constrained problem is:
\left(
\begin{array}{cc}
A & C^t \\ C & 0
\end{array}
\right)
\cdot
\left(
\begin{array}{c}
X \\ \lambda
\end{array}
\right)
\left(
\begin{array}{c}
B \\ T_0
\end{array}
\right)
where C is a row vector composed of V_i/V (the cell volume divided by the total volume) and \lambda is the Lagrange multiplier associated to the constraint.
This way the constraint is implicitly solved. We can also imagine the same kind of contraint on a part of the domain, on a surface of the domain, or involving more than one unknown, etc.
Is there any way to solve such a problem with implicit or explicit method?
If yes, how behaves the linear solvers with such a matrix to invert?
Best regards,
Sébastien
RGUP likes this.
sebastien.cadalen is offline   Reply With Quote
Old   April 2, 2019, 14:23
charles4allme is on a distinguished road
Were you able to figure out the solution to a problem. I am trying to add a constraint equation in OpenFOAM
charles4allme is offline   Reply With Quote
Old   September 21, 2021, 06:26
fanny is on a distinguished road
Hi all,
I would also want to impose a constraint as an integral relation over the whole fluid domain, but I do not know how to to do it..
Do you have some ideas ?
May I use " fvOptions type vectorDomainIntegral; " ? How it works ? Is there somewhere any tutorial ?
Thank you
Fanny
PS: I am using OpenFOAM v7.
fanny is offline   Reply With Quote
Solve poisson equation just add a source term nandiganavishal OpenFOAM Running, Solving & CFD 18 November 14, 2022 09:12
add temperature equation to interFoam nygbook OpenFOAM Running, Solving & CFD 3 September 4, 2011 07:28
what is the condition to use the wave equation? mmff Main CFD Forum 0 January 26, 2010 04:25
Derivation of Momentum Equation in Integral Form Demonwolf Main CFD Forum 2 October 29, 2009 19:53
UDF to add two governing equation?? T.K. Yang FLUENT 0 May 9, 2006 02:54
