simpleSRFfoam : request for volVectorField U
Old   October 19, 2010, 16:27
Default simpleSRFfoam : request for volVectorField U
jmf
Jean-Michel FONTAINE
jmf is on a distinguished road
Hi everybody
I try to model a rotor in an open stream, using simpleSRFoam.
The solvers returns :
--> FOAM FATAL ERROR:
    request for volVectorField U from objectRegistry region0 failed
    available objects of type volVectorField are
1
Urel
    From function objectRegistry::lookupObject<Type>(const word&) const
    in file /home/nous/OpenFOAM/OpenFOAM-1.7.1/src/OpenFOAM/lnInclude/objectRegistryTemplates.C at line 139.
In folder /0, there is a file Urel as follow :
internalField   uniform (10 0 0);
boundaryField
    inlet
        type            fixedValue;
        inletValue      uniform (10 0 0);
        relative        no;
        value           uniform (10 0 0);
    outlet
        type            freestream;
        freestreamValue uniform (10 0 0);
    rotor
        type            SRFVelocity;
        inletValue      uniform (0 0 0);
        relative        yes;
        value           uniform (0 0 0);
    cyclic
        type            cyclic;
In /system, fvSolution contains :
    Urel
        solver          PBiCG;
        preconditioner  DILU;
        tolerance       1e-05;
        relTol          0.1;
I'm sticked. Who might help me ?
Thanks in advance
Jean-Michel
jmf is offline   Reply With Quote
Old   October 23, 2010, 13:02
Default [solved] simpleSRFfoam : request for volVectorField U
jmf
Hello
My problem is solved : freeStream BC seems not to be compatible with simpleSRFFoam.
fixedValue fixed the error
Best wishes
Jean-Michel
Old   October 29, 2010, 20:11
M. Montero
be_inspired is on a distinguished road
I have problems with SRFsimpleFoam. My mesh is 3D, it is a 120º sector with cyclic condition. Continuity errors are increasing at each iteration.
Could you share some information about bcs? Inlet, outlet, cyclic, wall and exterior fardfield?
Thanks in advance
be_inspired is offline   Reply With Quote
Old   July 28, 2015, 15:16
Cool
Werner
WernerW is on a distinguished road
i'm experiencing the same issue with the request for volVectorField U as JMF. I'm following your advice to change the boundary conditions where there is freestream (with an exterior flow) from SRFFreestream to fixedValue and to zeroGradient and it still doesn't work.
I think that the zeroGradient boundary condition is better since I don't have a wall in here. For the fixedValue BC's I should give the walls the same speed of the air, which must be very difficult.
I think I might have to mention the volVectorField U somewhere since I eventually would want to have such vector field as a result. Are you sure that the solution to this problem relies only in the definitions of the boundary conditions ?
I will attach the versions of the Urel that I have created. I have followed the SFRSimpleFoam/Mixer to set up the fvSolution and fvSchemes. I attach them here as well.
I would apreciate any help.
Regards,
Werner
WernerW is offline   Reply With Quote
Old   January 21, 2019, 07:58
Default foam-extend 4.0
Luis Fernando
ingarcia1703 is on a distinguished road
Using the solver steadyCOmpressibleSRFFoam still find the error
4
UrelPrevIter
Urot
Urel
Uabs
I already changed the boundary conditions but is not working. Any idea?
Regards
ingarcia1703 is offline   Reply With Quote
Old   July 24, 2019, 09:35
Default solved
Luis Fernando
Hello foamers
The issue appeared because at the inlet boundary condition of temperature did not specify the U field as Urel, therefore the solver did not find the value. THen, by specifying U as U rel the problem has been solved.
Regards
boundary, field, srf, urel
Problem with paraFoam ata OpenFOAM 14 November 30, 2009 04:23
Installation OF1.5-dev ttdtud OpenFOAM Installation 46 May 5, 2009 02:32
[OpenFOAM] Xwindows crash with paraview save srinath ParaView 1 October 15, 2008 09:37
Request to provide information Sanjay Jain FLUENT 1 December 31, 2007 05:40
Memory request Giovanni Siemens 1 September 10, 2001 12:21
