GAMG crashes in OpenFOAM 1812
Old   May 12, 2019, 10:55
Default GAMG crashes in OpenFOAM 1812
Ehsan Asgari
syavash is on a distinguished road
Dear All,
When I try to run the tutorial of channel395 with OF 1812 using GAMG (default), the simulation crashes with the following error:
PIMPLE: iteration 1
smoothSolver:  Solving for Ux, Initial residual = 0.00317098, Final residual = 9.6554e-07, No Iterations 1
smoothSolver:  Solving for Uy, Initial residual = 0.003193, Final residual = 9.5391e-07, No Iterations 1
smoothSolver:  Solving for Uz, Initial residual = 0.00303762, Final residual = 9.22401e-07, No Iterations 1
#0  Foam::error::printStack(Foam::Ostream&) at ??:?
#1  Foam::sigFpe::sigHandler(int) at ??:?
#2  ? in /lib64/libpthread.so.0
#3  Foam::GAMGSolver::scale(Foam::Field<double>&, Foam::Field<double>&, Foam::lduMatrix const&, Foam::FieldField<Foam::Field, double> const&, Foam::UPtrList<Foam::lduInterfaceField const> const&, Foam::Field<double> const&, unsigned char) const at ??:?
#4  Foam::GAMGSolver::Vcycle(Foam::PtrList<Foam::lduMatrix::smoother> const&, Foam::Field<double>&, Foam::Field<double> const&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::Field<double>&, Foam::PtrList<Foam::Field<double> >&, Foam::PtrList<Foam::Field<double> >&, unsigned char) const at ??:?
#5  Foam::GAMGSolver::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const at ??:?
#6  Foam::fvMatrix<double>::solveSegregated(Foam::dictionary const&) at ??:?
#7  Foam::fvMatrix<double>::solveSegregatedOrCoupled(Foam::dictionary const&) at ??:?
#8  ? at ??:?
#9  __libc_start_main in /lib64/libc.so.6
#10  ? at ??:?
Floating point exception
I tried to run another tutorial (airfoil2D) which uses GAMG as default for pressure. However, it crashes similarly. I tried PCG for the first case and it was fine though. I have no idea what may be wrong here! Any help?
Syavash
syavash is offline   Reply With Quote
Old   May 13, 2019, 10:38
Ehsan Asgari
I wonder NOT a single person run into a similar problem with OF v1812? Any idea?
Old   February 14, 2021, 21:16
Michael
phi4ever is on a distinguished road
I got a similar error, same floating point exception. I resolved this by changing the relaxation factors to slow down the convergence. In my case the results were blowing up, which led to the floating point exception.
phi4ever is offline   Reply With Quote
decompose dependent solution arionfard OpenFOAM 3 December 10, 2018 10:36
Help for the small implementation in turbulence model shipman OpenFOAM Programming & Development 25 March 19, 2014 11:08
pisoFoam with k-epsilon turb blows up - Some questions Heroic OpenFOAM Running, Solving & CFD 26 December 17, 2012 04:34
Differences between serial and parallel runs carsten OpenFOAM Bugs 11 September 12, 2008 12:16
SonicTurbFoam crashes when turbulence is added gastovski OpenFOAM Running, Solving & CFD 0 January 21, 2008 08:49
