Pressure field fluctuation in y and z directions
Hi all,
I am experiencing some irregular fluctuations in my pressure output from OpenFOAM. More specifically, the y,z direction pressure measurements fluctuates quite a bit at random times, when the x direction does not. Example is shown here: https://ibb.co/445hh5m , which is the y-direction component of the pressure. I have performed several other simulations of the exact same model, where the only thing i've changed is the velocity Um, and they worked fine. I don't know which dictionaries you might need in order to help me, so please ask me, and i will upload it straight away. Hope some of you can help. |
Hi Rasmus,
May I ask if you have found the reason? I am experiencing the same strange pressure fluctuation behavior. Best |
I don't recall exactly, but my end results did not show this behaviour. I found that irregularities like the are often associated with the diacretization in either time or space. In my case I am pretty sure it was in space. So different og higher refinements near the structures or a larger domain all together. Too small domains can result in blocking effects, which you do not want. Hope this helps, although it is a timely effort to reduce the fluctuations. |
