unknown error in openfoam
I made a new solver which compiles correctly and I created a configuration which works correctly with other solvers can anyone please help me on following error:
/*---------------------------------------------------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 6 \\/ M anipulation | \*---------------------------------------------------------------------------*/ Build : 6-e29811f5dff8 Exec : Mixedbonj Date : Jun 22 2019 Time : 12:27:28 Host : "siamak-HP-ZBook-15-G3" PID : 10086 I/O : uncollated Case : /home/siamak/Desktop/validation/squareCavity nProcs : 1 sigFpe : Enabling floating point exception trapping (FOAM_SIGFPE). fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10) allowSystemOperations : Allowing user-supplied system call operations // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // Create time Create mesh for time = 0 SIMPLE: Convergence criteria found p_rgh: tolerance 1e-06 p: tolerance 1e-06 U: tolerance 1e-06 T: tolerance 1e-06 V: tolerance 1e-06 "(k|epsilon|omega)": tolerance 1e-05 Reading thermophysical properties Reading field T Reading field V Reading field p_rgh Reading field U Reading field Teta Reading/calculating face flux field phi Selecting incompressible transport model Newtonian Creating turbulence model Selecting turbulence model type laminar Selecting laminar stress model Stokes #0 Foam::error::printStack(Foam::Ostream&) at ??:? #1 Foam::sigFpe::sigHandler(int) at ??:? #2 ? in "/lib/x86_64-linux-gnu/libc.so.6" #3 Foam::dimensioned<double> Foam::operator/<double>(Foam::dimensioned<double> const&, Foam::dimensioned<double> const&) in "/home/siamak/OpenFOAM/siamak-6/platforms/linux64GccDPInt32Opt/bin/Mixedbonj" #4 ? in "/home/siamak/OpenFOAM/siamak-6/platforms/linux64GccDPInt32Opt/bin/Mixedbonj" #5 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6" #6 ? in "/home/siamak/OpenFOAM/siamak-6/platforms/linux64GccDPInt32Opt/bin/Mixedbonj" Floating point exception (core dumped) http://www.mediafire.com/file/y2s0ye...avity.zip/file http://www.mediafire.com/file/ctr57ii1opnk3lo/Mixedbonj.zip/file first link is configuration file and the 2nd one is solver's. thanks in advance Siamak |
some more information about this error
I find that error comes from these lines and when I delete them no bugs occur:
// thermal capacity of nanofluid dimensionedScalar Cpnf = ((Cv*rhoP+(1.0-Cv)*rhoRefbf)/rhonf) ; //ratio of product of rhoCp of particle to rhoCp of nanofluid dimensionedScalar rhoCp_ratio = (rhoP*Cpp/(rhoRefbf*Cpbf)); // Brownian diffusion coefficient of nanofluid volScalarField DB ( IOobject ( "DB", runTime.timeName(), mesh ), (KB*T/(3.0*3.14159265*miunf*dp)) ); // Thermal diffusion coefficient of nanofluid volScalarField DT ( IOobject ( "DT", runTime.timeName(), mesh ), ((miunf*V*0.26*Knf)/(rhonf*rhok*(2.0*Knf+Kp))) ); Also I find out problem is from denominator part ? all of denominator parts are dimensionedScalar elements !!! can anyone guess something ? |
