Convergence blues
3 Attachment(s)
Im running a simpleFoam case with k-e. After approximately 570 iterations the simulation crashes. Any general ideas on what might cause this? Attached the residuals and the instability - the velocity goes through the roof.. regards |
Does checkMesh complain about the mesh quality?
Hi jherb,
I think the mesh is ok.. see below: Mesh stats points: 171587 faces: 1781432 internal faces: 1682136 cells: 865892 faces per cell: 4 boundary patches: 7 point zones: 0 face zones: 0 cell zones: 0 Overall number of cells of each type: hexahedra: 0 prisms: 0 wedges: 0 pyramids: 0 tet wedges: 0 tetrahedra: 865892 polyhedra: 0 Checking topology... Boundary definition OK. Cell to face addressing OK. Point usage OK. Upper triangular ordering OK. Face vertices OK. Number of regions: 1 (OK). Checking patch topology for multiply connected surfaces... Patch Faces Points Surface topology inlet1 238 141 ok (non-closed singly connected) inlet2 232 138 ok (non-closed singly connected) outlet1 232 138 ok (non-closed singly connected) outlet2 234 139 ok (non-closed singly connected) sym 36380 18443 ok (non-closed singly connected) wall1 48840 24753 ok (non-closed singly connected) pipes 13140 6738 ok (non-closed singly connected) Checking faceZone topology for multiply connected surfaces... No faceZones found. Checking basic cellZone addressing... No cellZones found. Checking geometry... Overall domain bounding box (0 0 0) (194 189 13) Mesh has 3 geometric (non-empty/wedge) directions (1 1 1) Mesh has 3 solution (non-empty) directions (1 1 1) Boundary openness (-1.05596e-16 6.78774e-18 3.33865e-15) OK. Max cell openness = 2.51381e-16 OK. Max aspect ratio = 6.12287 OK. Minimum face area = 0.00594874. Maximum face area = 4.18215. Face area magnitudes OK. Min volume = 0.000219401. Max volume = 2.55495. Total volume = 464436. Cell volumes OK. Mesh non-orthogonality Max: 52.7944 average: 14.6586 Non-orthogonality check OK. Face pyramids OK. Max skewness = 0.688954 OK. Coupled point location match (average 0) OK. Mesh OK. End |
Ok. Step by step. What are the settings in fvSchemes and fvSolutions?
2 Attachment(s)
Hi jherb...thanks for the reply.. attached the settings:
Ok, just guesses: You could try to increase the nNonOrthogonalCorrectors to something like 2 or 3 and reduce the relaxation factors.
It works when I reduce the k,e & U relaxation to 0.2 at the start of the simulation then gradually increase to 0.5. The 0.2 seems a bit low but the results are looking ok I think.
