rhoPimpleFoam - Pressure cyclic fluctuations
Like Tree2Likes
  • 2 Post By sjohn2
Old   July 1, 2019, 15:48
Default rhoPimpleFoam - Pressure cyclic fluctuations
Stanley John
sjohn2 is on a distinguished road
I am trying to simulate a nozzle flow of water/steam, using rhoPimpleFoam solver.
I am getting cyclic fluctuations in pressure i.e pressure fields alternates every 3-4 times steps between the 2 figures. Basically the pressure does not converge.
However the velocity fields looks OK
PHP Code:
My boundary conditions are:
FoamFile
version     2.0;
format      ascii;
    class
volScalarField;
object      p;
Pin   248000;
Pout   127000;
dimensions      [--2 0 0];
internalField   uniform $Pout;
boundaryField
INLET
type          totalPressure;
p0           uniform $Pin;
OUTLET
type          fixedValue;
value         uniform $Pout;
WALL
type            zeroGradient;
SYMM
type            symmetry;
SIDE1
type            empty;
SIDE2
type            empty;
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
volVectorField;
object      U;
dimensions      [0 1 -1 0 0];
internalField   uniform (5.97 0 0);
boundaryField
INLET
type            pressureInletVelocity;
value           $internalField;
OUTLET
type        zeroGradient;
WALL
type            noSlip;
SYMM
type            symmetry;
SIDE1
type            empty;
SIDE2
type            empty;
Thermohysical properties are
PHP Code:
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
location    "constant";
object      thermodynamicProperties;
thermoType
type            heRhoThermo;
mixture         pureMixture;
properties      liquid;
energy          sensibleInternalEnergy;
mixture
H2O;
I am out of idea, what can be the possible problem Any suggestions?
sjohn2 is offline   Reply With Quote
Old   July 1, 2019, 20:06
Default Update!
Stanley John
I tried solving the same problem using rhoSimpleFoam; which uses the Simple algorithm to solve for pressure field, with the same boundary conditions and the pressure field problem vanishes.
I get the pressure field as:
and the velocity field as:
The problem I need to use cavitatingFoam which is based on PIMPLE algorithm and I need to get PIMPLE running,
Any suggestions?
Old   July 2, 2019, 15:15
Stanley John
I got the solution to work finally, the change that I made to the fvsolution file in the PIMPLE part is turn on transonic. Now the pressure plot looks like this,
and the velocity plot is,
Does anyone have any feedback/advice in the settings for transonic/supersonic flows?
Here is my fv solution
PHP Code:
/*--------------------------------*- C++ -*----------------------------------*\
  \\      /  F ield         | OpenFOAM: The Open Source CFD Toolbox
   \\    /   O peration     | Website:  [url]https://openfoam.org[/url]
    \\  /    A nd           | Version:  6
     \\/     M anipulation  |
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
location    "system";
object      fvSolution;
solvers
rho
solver          PCG;
preconditioner  DIC;
tolerance       1e-5;
relTol          0.1;
rhoFinal
$rho;
tolerance       1e-5;
relTol          0;
"p.*"
solver          GAMG;
smoother        GaussSeidel;
tolerance       1e-7;
relTol          0;
"(U|e|k|epsilon).*"
solver          PBiCGStab;
preconditioner  DILU;
tolerance       1e-7;
relTol          0;
PIMPLE
momentumPredictor   yes;
transonic           yes;
nOuterCorrectors    3;
nCorrectors         1;
nNonOrthogonalCorrectors 0;
pMaxFactor          1.2;
pMinFactor          0.8;
residualControl
U   1e-5;
p  5e-7;
relaxationFactors
fields
p      0.3;
pFinal   1;
equations
".*"            0.8;
and fvschemes file:
PHP Code:
   \\    /   O peration     | Website:  https://openfoam.org
     \\/     M anipulation  |
FoamFile
version     2.0;
format      ascii;
    class
dictionary;
location    "system";
object      fvSchemes;
ddtSchemes
    default
Euler;
gradSchemes
    default
Gauss linear;
limited             cellLimited Gauss linear 1;
divSchemes
    default
none;
div(phi,U)          Gauss linearUpwind limited;
div(phi,e)          Gauss linearUpwind limited;
div(phi,epsilon)    Gauss linearUpwind limited;
div(phi,k)          Gauss linearUpwind limited;
div(phi,K)          Gauss linearUpwind limited;
div(phiv,p)         Gauss linearUpwind limited;
div(phid,p)         Gauss linearUpwind limited;
div(((rho*nuEff)*dev2(T(grad(U)))))      Gauss linear;
laplacianSchemes
    default
Gauss linear corrected;
interpolationSchemes
    default
linear;
snGradSchemes
    default
corrected;
jfolio and uckmhnds like this.
outlet pressure Boundary settings -velocity streamline under ambient temp.conditions Vishnu_bharathi CFX 12 November 21, 2017 07:56
interFoam (HELYX-OS) pressure boundary conditions SFr OpenFOAM Running, Solving & CFD 8 June 23, 2016 17:36
rhoPimpleFoam Initial Setup Queries for a Flow Generated due to Pressure B.C umer.chaudrey OpenFOAM 1 October 4, 2011 04:52
Pressure reference in cyclic interFoam AlmostSurelyRob OpenFOAM 7 February 16, 2011 10:58
About Pressure Field with Cyclic Boundary Conditio Jiaying Xu Siemens 2 October 4, 2001 10:11
