Simulation aborted with reactingFoam
3 Attachment(s)
I am trying to simulate a burner, my geometry is basicaly a pipe with an entry of methane and multiple entry of air around it. I use realizable k epsilon turbulence model and i launch my simulation in parallel. The solver used is reactingFoam.
Unfortunately my simulation keep aborting with this error shown in the terminal after doing 11 iteration with 0.00001 time step:
[0] #0 Foam::error::printStack(Foam::Ostream&) at ??:?
[0] #1 Foam::sigFpe::sigHandler(int) at ??:?
[0] #2 ? in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #3 Foam::sqrt(Foam::Field<double>&, Foam::UList<double> const&) at ??:?
[0] #4 Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > Foam::sqrt<Foam::fvPatchField, Foam::volMesh>(Foam::tmp<Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> > const&) at ??:?
[0] #5 Foam::RASModels::realizableKE<Foam::EddyDiffusivity<Foam::ThermalDiffusivity<Foam::CompressibleTurbulenceModel<Foam::fluidThermo> > > >::correct() at ??:?
[0] #6 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/reactingFoam"
[0] #7 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
[0] #8 ? in "/opt/openfoam-dev/platforms/linux64GccDPInt32Opt/bin/reactingFoam"
[ubuntu1:09248] *** Process received signal ***
[ubuntu1:09248] Signal: Floating point exception (8)
[ubuntu1:09248] Signal code: (-6)
[ubuntu1:09248] Failing at address: 0x3e900002420
[ubuntu1:09248] [ 0] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7ff006941f20]
[ubuntu1:09248] [ 1] /lib/x86_64-linux-gnu/libc.so.6(gsignal+0xc7)[0x7ff006941e97]
[ubuntu1:09248] [ 2] /lib/x86_64-linux-gnu/libc.so.6(+0x3ef20)[0x7ff006941f20]
[ubuntu1:09248] [ 3] /opt/openfoam-dev/platforms/linux64GccDPInt32Opt/lib/libOpenFOAM.so(_ZN4Foam4sqrtERNS_5FieldIdEERKNS_5UListIdEE+0x3a)[0x7ff007f2bfea]
[ubuntu1:09248] [ 4] /opt/openfoam-dev/platforms/linux64GccDPInt32Opt/lib/libfiniteVolume.so(_ZN4Foam4sqrtINS_12fvPatchFieldENS_7volMeshEEENS_3tmpINS_14GeometricFieldIdT_T0_EEEERKS8_+0x18e)[0x7ff00d63db4e]
[ubuntu1:09248] [ 5] /opt/openfoam-dev/platforms/linux64GccDPInt32Opt/lib/libcompressibleTurbulenceModels.so(_ZN4Foam9RASModels12realizableKEINS_15EddyDiffusivityINS_18ThermalDiffusivityINS_27CompressibleTurbulenceModelINS_11fluidThermoEEEEEEEE7correctEv+0x514)[0x7ff00b6062c4]
[ubuntu1:09248] [ 6] reactingFoam(+0x306c8)[0x55b2d1a326c8]
[ubuntu1:09248] [ 7] /lib/x86_64-linux-gnu/libc.so.6(__libc_start_main+0xe7)[0x7ff006924b97]
[ubuntu1:09248] [ 8] reactingFoam(+0x3530a)[0x55b2d1a3730a]
[ubuntu1:09248] *** End of error message ***
mpirun noticed that process rank 0 with PID 0 on node ubuntu1 exited on signal 8 (Floating point exception).
I attached my "chechMesh -allGeometry -allTopology", fvSolution and fvSchemes files.
I don't know how to correct this, if anyone already had to face this problem and could help me, it would be nice !
Thank you.
