July 11, 2019, 10:54 |
noSlip boundary condition and Turbulent flow
Raza Javed
Rep Power: 7 |
Hello Everyone,
I have a question that, If I have Turbulent fluid flow from a pipe, Can I use noSlip boundary condition for velocity(U) at the walls of the pipe? I shall be very thankful for your helpful response. Thank you |
July 12, 2019, 02:23 |
Ingo Riess
Rep Power: 6 |
I am currently building a case where I initially used noSlip boundary condition on the side walls. It gave me a considerable and grid-dependent pressure drop through my system. Now I changed to nutkWallFunction and then to nutkRoughWallFunction. Both gave me more reasonable pressure drop. I assume, for noSlip boundary condition you have to resolve the boundary layer with your grid... and possibly be careful with the selection of the turbulence model.
July 12, 2019, 02:57 |
#3 | |
Raza Javed
Rep Power: 7 |
Thank you so much for your reply. Can we use nutkwallfunction or other wallFunctions for velocity boundary conditions as well? I thought we can only use them for 'k' in turbulence modelling. |
July 12, 2019, 03:01 |
Ingo Riess
Rep Power: 6 |
I see, you're right. I use noSlip for 'U', nutkRoughWallFunction for 'nut' and kqRWallFunction for 'k'. Not sure if this is right. At least, the pressure drop in my system appears reasonable.
There are so many tutorials on meshing and application selection - I wish there'd be more on boundary conditions. |
boundary conditions, noslip, openfoam, turbulent flow, velocity |
Issues on the simulation of high-speed compressible flow within turbomachinery | dowlee | OpenFOAM Running, Solving & CFD | 11 | August 6, 2021 06:40 |
CFD analaysis of Pelton turbine | amodpanthee | CFX | 31 | April 19, 2018 18:02 |
Wrong flow in ratating domain problem | Sanyo | CFX | 17 | August 15, 2015 06:20 |
An error has occurred in cfx5solve: | volo87 | CFX | 5 | June 14, 2013 17:44 |
Low Mixing time Problem | Mavier | CFX | 5 | April 29, 2013 00:00 |
