New error based on 'boundaryFoam', 'boundaryWallFunctionsProfile' case study.
Hello All,
So, I asked earlier about the chances of changing the boundary conditions in 'boundaryFoam' solver from 'cyclic' to flow velocity. And din't receive any reply so I just decided to change myself and I received following error: Code:
/*---------------------------------------------------------------------------*\ Can anyone explain me this error, or help me solve this error? If anyone helps me, will be generously awarded? I'll just give you this entire case study, if anyone solves it. Because, other than 'cyclic' boundary conditions this solver not been used. So, you can put up paper stating new boundary condition implementation along with all types of turbulence study on this specific geometry! |
Did you find the problem?
I ran accross this issue trying to run the surface mounted cube tutorials. I modified the mesh, ran boundaryFoam and got this. Not sure how to proceed from here. |
Did you able to fix this issue ?
boundaryFoam is solver only for boundary.
look your tutrials boundaryWallFunctionsProfile/system/blockMeshDict/blocks it must be like this blocks ( hex (0 1 2 3 4 5 6 7) (1 40 1) simpleGrading (1 1 1) ); boundaryfoam can only solve sliced mesh so never change (10 40 1) or something like that. |
