How can a lower bound for p_rgh be set in chtMultiRegionFoam? |
August 9, 2019, 12:39 |
Michael K
I am simulation of a nozzle exhaust and have been able to successfully model it using rhoPimpleFoam. To do this I had to use the pMin entry in the PIMPLE dictionary and set it to a very low pressure, 100 Pa (my nozzle is exhausting to a pressure of 500 Pa). I then wanted to use chtMultiRegionFoam with the same fluid case in the fluid region. Unfortunately even though the pMin entry entry sets the p field, this has no effect on the p_rgh field that the solver is computing.
How can I limit the p_rgh field? I am using v1906, but I think this question is applicable to all solvers that compute p_rgh in any version of OpenFoam. |
chtmultiregionfoam, pmin, p_rgh |
correction of Grub after installing Windows XP and 8 | immortality | Lounge | 20 | January 5, 2014 17:41 |
Help with GNUPlot | Renato. | Main CFD Forum | 6 | June 6, 2007 19:51 |
How do I set lower temperature boundary limit? | Arefin Anwar | CFX | 1 | December 4, 2006 09:48 |
How do I set Lower temperature boundary limit? | Arefin Anwar | CFX | 0 | December 4, 2006 02:31 |
Warning 097- | AB | Siemens | 6 | November 15, 2004 04:41 |
