momentum_equation |
August 7, 2019 01:35 |
Error when "wmake"
I have been trying to create a solver capable of solving passive temperature scalar by modifying pimpleDyMFoam. Whenever I try to compile I get the following error:
Make/linux64GccDPInt64Opt/options:62: *** missing separator. Stop.
wmake error: file 'Make/linux64GccDPInt64Opt/sourceFiles' could not be created
I also checked for whitespaces in all the make files, but still it shows the same error.
solver .C file is as follows:
#include "fvCFD.H"
#include "dynamicFvMesh.H"
#include "singlePhaseTransportModel.H"
#include "turbulentTransportModel.H"
#include "pimpleControl.H"
#include "CorrectPhi.H"
#include "fvIOoptionList.H"
#include "fixedFluxPressureFvPatchScalarField.H"
int main(int argc, char *argv[])
#include "setRootCase.H"
#include "createTime.H"
#include "createDynamicFvMesh.H"
#include "initContinuityErrs.H"
pimpleControl pimple(mesh);
#include "createFields.H"
#include "createUf.H"
#include "createMRF.H"
#include "createFvOptions.H"
#include "createControls.H"
#include "CourantNo.H"
#include "setInitialDeltaT.H"
Info<< "\nStarting time loop\n" << endl;
while (runTime.run())
#include "readControls.H"
#include "setDeltaT.H"
runTime++;
Info<< "Time = " << runTime.timeName() << nl << endl;
// Added dynmaic mesh update.
mesh.update();
// Calculate absolute flux from the mapped surface velocity
phi = mesh.Sf() & Uf;
if (mesh.changing() && correctPhi)
#include "correctPhi.H"
// Make the flux relative to the mesh motion
fvc::makeRelative(phi, U);
if (mesh.changing() && checkMeshCourantNo)
#include "meshCourantNo.H"
// --- Pressure-velocity PIMPLE corrector loop
while (pimple.loop())
#include "UEqn.H"
#include "TEqn.H"
// --- Pressure corrector loop
while (pimple.correct())
#include "pEqn.H"
if (pimple.turbCorr())
laminarTransport.correct();
turbulence->correct();
runTime.write();
Info<< "ExecutionTime = " << runTime.elapsedCpuTime() << " s"
<< " ClockTime = " << runTime.elapsedClockTime() << " s"
<< nl << endl;
Info<< "End\n" << endl;
return 0;
