-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   Solver crashing when water reaches specific part of geometry (https://www.cfd-online.com/Forums/openfoam-solving/219853-solver-crashing-when-water-reaches-specific-part-geometry.html)
Nosravi August 12, 2019 04:00
Hello!
I am running interFoam on OpenFOAM for Windows v1812.
I am trying to simulate a river flowing over a small dam structure. The mesh is rather complicated, but after using snappyHexMesh and checkMesh, there are no errors. CheckMesh output:
Checking geometry...
Overall domain bounding box (-61.5 -12.8416 -5.7553) (61.5 12.1276 6)
Mesh has 3 geometric (non-empty/wedge) directions (1 1 1)
Mesh has 3 solution (non-empty) directions (1 1 1)
Boundary openness (6.09426e-17 2.2781e-18 6.66016e-16) OK.
Max cell openness = 4.12308e-16 OK.
Max aspect ratio = 7.84984 OK.
Minimum face area = 0.00627443. Maximum face area = 3.92051. Face area magnitudes OK.
Min volume = 0.00609986. Max volume = 6.2164. Total volume = 14660.8. Cell volumes OK.
Mesh non-orthogonality Max: 58.5746 average: 17.1615
Non-orthogonality check OK.
Face pyramids OK.
Max skewness = 3.77688 OK.
Coupled point location match (average 0) OK.
Mesh OK.
However, when i run interFoam, no matter which refinement level my mesh is at, the Courant number explodes around the time the water hits the dam. Increasing the inlet velocity makes the solver diverge sooner, as the water hits the dam earlier. This makes me expect that something has to be done with the dam geometry.
I've been told earlier that interFoam is picky about the mesh, especially regarding skewness and orthogonality. I don't know which values I should aim for to make sure the mesh is good enough.
Does anyone have any experience with similar cases, or have any suggestions how to move forward?
Imgur album of geometry and Paraview results:
https://imgur.com/a/9B8c4NQ
Cheers!
simrego August 12, 2019 06:48
Hi!
Can you share your fvSolution? And try with pure 1st order schemes, and if it is working you can go for higher order ones.
I know you wrote the mest resolution, but I think this is really poor... What if you try to refine only around the dam.
And what is your allowed max Co and alphaCo? Or are you using fixed time steps?
Nosravi August 12, 2019 07:17
Thanks for the reply!
Here is my fvSolutions:
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    location    "system";
    object      fvSolution;
solvers
    "alpha.water.*"
        nAlphaCorr      1;
        nAlphaSubCycles 1;
        cAlpha          1;
        MULESCorr      yes;
        nLimiterIter    3;
        solver          smoothSolver;
        smoother        symGaussSeidel;
        tolerance      1e-8;
        relTol          0;
    pcorr
        solver          PCG;
        preconditioner
            preconditioner  GAMG;
            tolerance      1e-5;
            relTol          0;
            smoother        GaussSeidel;
            nPreSweeps      0;
            nPostSweeps    2;
            nFinestSweeps  2;
            cacheAgglomeration true;
            nCellsInCoarsestLevel 10;
            agglomerator    faceAreaPair;
            mergeLevels    1;
        tolerance      1e-5;
        relTol          0;
        maxIter        50;
    p_rgh
        solver          GAMG;
        tolerance        5e-9;
        relTol          0.01;
        nPreSweeps      0;
        nPostSweeps      2;
        mergeLevels      1;
        maxIter          50;
    p_rghFinal
        $p_rgh;
        tolerance      5e-9;
        relTol          0;
    pcorrFinal
        $pcorr;
        tolerance      5e-9;
        relTol          0;
    "(U|k|epsilon).*"
        nSweeps        1;
        tolerance      1e-6;
        relTol          0.1;
PIMPLE
    momentumPredictor no;
    nCorrectors    2;
    nNonOrthogonalCorrectors 0;
relaxationFactors
    fields
    equations
        ".*" 1;
Do you have any specific schemes that you recommend I try? I'm sorry, I am not that used to CFD modelling yet. This is my fvSchemes:
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default        Euler;
gradSchemes
    default        Gauss linear;
divSchemes
    div(rhoPhi,U)  Gauss linearUpwind grad(U);
    div(phi,alpha)  Gauss vanLeer;
    div(phirb,alpha) Gauss linear;
    div(phi,k)      Gauss upwind;
    div(phi,epsilon)  Gauss upwind;
    div(((rho*nuEff)*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
    default        Gauss linear corrected;
interpolationSchemes
    default        linear;
snGradSchemes
    default        corrected;
wallDist
    method meshWave;
I have been wondering if I can refine just the dam area, however, I am unsure how to do that.
I am using adjustableTimestep. maxCo is 0.9 and alphaCo is 0.5
simrego August 12, 2019 07:29
So first of all you just using PISO not the PIMPLE algorithm. Try something like this: But you can modify mostly the residuals (probably you will have to tighten the tolerances but try with these for the first time) entry and the nOuterCorrrectors part. The first timesteps will be pretty slow (you will have a lot of outer loop, but as you go further you will need less and less.
PIMPLE
    nOuterCorrectors    50;
    nCorrectors        1;
    correctPhi          yes;
    moveMeshOuterCorrectors no;
    turbOnFinalIterOnly    no;
    residualControl
        U
                tolerance  1e-4;
                absTol      0;
                relTol      0;
        p_rgh
                tolerance  1e-4;
                absTol      0;
                relTol      0;
        k
                tolerance  1e-3;
                absTol      0;
                relTol      0;
        epsilon
                tolerance  1e-3;
                absTol      0;
                relTol      0;
Schemes:
For U and alpha, you can use a Gauss upwind like for k and epsilon. This is a really diffusive scheme, but hell stable so it is good for a starting point.
Refine:
In snappyHexMesh you can define a box for example. And you can refine the mesh in that region if you don't have your dam in a separate stl file.
Nosravi August 12, 2019 07:42
Thank you for good input!
The reason the mesh is coarse is because I am currently working on a normal laptop. My aim was to make it work on a coarse mesh first, then transfer the case to a more powerful computer for the high resolution simulation.
I do not need the river bed to be especially high res, the focal point is the dam. Therefore I will make sure to try and refine in a box just around the dam, like you said, to save some processing power!
I implemented your suggestions and am now running the simulation. Forgive my PC for working slowly hehe. I will update when the run is finished.
Nosravi August 13, 2019 03:42
After running the simulation with the 1st order schemes and PIMPLE, the simulation still diverges before reaching the dam, it diverges around 11.7s into the run.
This time I also used refinementRegion in sHM to make the mesh around the dam extra fine.
You were right in that the first steps take a bit longer, but after a bit it speeds up. I was hopeful that it would work this time, but unfortunalety not..
I will attach the relevant dictionaries.
| \\      /  F ield        | OpenFOAM: The Open Source CFD Toolbox          |
|  \\    /  O peration    | Version:  2.1.0                                |
|  \\  /    A nd          | Web:      www.OpenFOAM.org                      |
|    \\/    M anipulation  |                                                |
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    location    "system";
    object      controlDict;
application    interFoam;
startFrom      latestTime;
startTime      0;
stopAt          endTime;
endTime        40;
deltaT          0.05;
writeControl    adjustableRunTime;
writeInterval  0.1;
purgeWrite      0;
writeFormat    ascii;
writePrecision  6;
writeCompression off;
timeFormat      general;
timePrecision  6;
runTimeModifiable yes;
adjustTimeStep  yes;
maxCo          0.9;
maxAlphaCo      0.5;
maxDeltaT      1;
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    object      snappyHexMeshDict;
// Which of the steps to run
castellatedMesh true;
snap            true;
//snap            false;
addLayers      true;
//addLayers      false;
// Geometry. Definition of all surfaces. All surfaces are of class
// searchableSurface.
// Surfaces are used
// - to specify refinement for any mesh cell intersecting it
// - to specify refinement for any mesh cell inside/outside/near
// - to 'snap' the mesh boundary to the surface
geometry
    river.stl
        type triSurfaceMesh;
        name river;
  refinementBox
        type searchableBox;
        min (34 -12 -4);
        max (38 12 6);
// Settings for the castellatedMesh generation.
castellatedMeshControls
    // Refinement parameters
    // If local number of cells is >= maxLocalCells on any processor
    // switches from from refinement followed by balancing
    // (current method) to (weighted) balancing before refinement.
    maxLocalCells 1000000;
    // Overall cell limit (approximately). Refinement will stop immediately
    // upon reaching this number so a refinement level might not complete.
    // Note that this is the number of cells before removing the part which
    // is not 'visible' from the keepPoint. The final number of cells might
    // actually be a lot less.
    maxGlobalCells 4000000;
    // The surface refinement loop might spend lots of iterations refining just a
    // few cells. This setting will cause refinement to stop if <= minimumRefine
    // are selected for refinement. Note: it will at least do one iteration
    // (unless the number of cells to refine is 0)
    minRefinementCells 0;
    // Allow a certain level of imbalance during refining
    // (since balancing is quite expensive)
    // Expressed as fraction of perfect balance (= overall number of cells /
    // nProcs). 0=balance always.
    maxLoadUnbalance 0.10;
    // Number of buffer layers between different levels.
    // 1 means normal 2:1 refinement restriction, larger means slower
    // refinement.
    nCellsBetweenLevels 1;
    // Explicit feature edge refinement
    // Specifies a level for any cell intersected by its edges.
    // This is a featureEdgeMesh, read from constant/triSurface for now.
    features
    // Surface based refinement
    // Specifies two levels for every surface. The first is the minimum level,
    // every cell intersecting a surface gets refined up to the minimum level.
    // The second level is the maximum level. Cells that 'see' multiple
    // intersections where the intersections make an
    // angle > resolveFeatureAngle get refined up to the maximum level.
    refinementSurfaces
        river
            // Surface-wise min and max refinement level
            level (2 2);
    // Resolve sharp angles
    resolveFeatureAngle 40;
    // Region-wise refinement
    // Specifies refinement level for cells in relation to a surface. One of
    // three modes
    // - distance. 'levels' specifies per distance to the surface the
    //  wanted refinement level. The distances need to be specified in
    //  descending order.
    // - inside. 'levels' is only one entry and only the level is used. All
    //  cells inside the surface get refined up to the level. The surface
    //  needs to be closed for this to be possible.
    // - outside. Same but cells outside.
    refinementRegions
        refinementBox
            mode inside;
            levels ((2 4));
    // Mesh selection
    // After refinement patches get added for all refinementSurfaces and
    // all cells intersecting the surfaces get put into these patches. The
    // section reachable from the locationInMesh is kept.
    // NOTE: This point should never be on a face, always inside a cell, even
    // after refinement.
    locationInMesh (0 0 0);
    // Whether any faceZones (as specified in the refinementSurfaces)
    // are only on the boundary of corresponding cellZones or also allow
    // free-standing zone faces. Not used if there are no faceZones.
    allowFreeStandingZoneFaces true;
// Settings for the snapping.
snapControls
    //- Number of patch smoothing iterations before finding correspondence
    //  to surface
    nSmoothPatch 4;
    //- Relative distance for points to be attracted by surface feature point
    //  or edge. True distance is this factor times local
    //  maximum edge length.
    tolerance 3.0;
    //- Number of mesh displacement relaxation iterations.
    nSolveIter 70;
    //- Maximum number of snapping relaxation iterations. Should stop
    //  before upon reaching a correct mesh.
    nRelaxIter 20;
    //- Highly experimental and wip: number of feature edge snapping
    //  iterations. Leave out altogether to disable.
    //  Do not use here since mesh resolution too low and baffles present
    nFeatureSnapIter 25;
// Settings for the layer addition.
addLayersControls
    // Are the thickness parameters below relative to the undistorted
    // size of the refined cell outside layer (true) or absolute sizes (false).
    relativeSizes true;
    // Per final patch (so not geometry!) the layer information
    layers
    // Expansion factor for layer mesh
    expansionRatio 1.0;
    //- Wanted thickness of final added cell layer. If multiple layers
    //  is the
    //  thickness of the layer furthest away from the wall.
    //  Relative to undistorted size of cell outside layer.
    //  is the thickness of the layer furthest away from the wall.
    //  See relativeSizes parameter.
    finalLayerThickness 0.3;
    //- Minimum thickness of cell layer. If for any reason layer
    //  cannot be above minThickness do not add layer.
    minThickness 0.3;
    //- If points get not extruded do nGrow layers of connected faces that are
    //  also not grown. This helps convergence of the layer addition process
    //  close to features.
    // Note: changed(corrected) w.r.t 17x! (didn't do anything in 17x)
    nGrow 0;
    // Advanced settings
    //- When not to extrude surface. 0 is flat surface, 90 is when two faces
    //  make straight angle.
    featureAngle 60;
    nRelaxIter 5;
    // Number of smoothing iterations of surface normals
    nSmoothSurfaceNormals 1;
    // Number of smoothing iterations of interior mesh movement direction
    nSmoothNormals 3;
    // Smooth layer thickness over surface patches
    nSmoothThickness 10;
    // Stop layer growth on highly warped cells
    maxFaceThicknessRatio 0.5;
    // Reduce layer growth where ratio thickness to medial
    // distance is large
    maxThicknessToMedialRatio 0.3;
    // Angle used to pick up medial axis points
    // Note: changed(corrected) w.r.t 17x! 90 degrees corresponds to 130 in 17x.
    minMedianAxisAngle 90;
    // Create buffer region for new layer terminations
    nBufferCellsNoExtrude 0;
    // Overall max number of layer addition iterations. The mesher will exit
    // if it reaches this number of iterations; possibly with an illegal
    // mesh.
    nLayerIter 50;
// Generic mesh quality settings. At any undoable phase these determine
// where to undo.
meshQualityControls
    //- Maximum non-orthogonality allowed. Set to 180 to disable.
    maxNonOrtho 65;
    //maxNonOrtho 180;
    //- Max skewness allowed. Set to <0 to disable.
    maxBoundarySkewness 20;
    maxInternalSkewness 3;
    //- Max concaveness allowed. Is angle (in degrees) below which concavity
    //  is allowed. 0 is straight face, <0 would be convex face.
    //  Set to 180 to disable.
    maxConcave 80;
    //maxConcave 180;
    //- Minimum pyramid volume. Is absolute volume of cell pyramid.
    //  Set to a sensible fraction of the smallest cell volume expected.
    //  Set to very negative number (e.g. -1E30) to disable.
    minVol 1e-13;
    //- Minimum quality of the tet formed by the face-centre
    //  and variable base point minimum decomposition triangles and
    //  the cell centre. This has to be a positive number for tracking
    //  to work. Set to very negative number (e.g. -1E30) to
    //  disable.
    //    <0 = inside out tet,
    //      0 = flat tet
    //      1 = regular tet
    minTetQuality 1e-30;
    //- Minimum face area. Set to <0 to disable.
    minArea -1;
    //- Minimum face twist. Set to <-1 to disable. dot product of face normal
    //- and face centre triangles normal
    minTwist 0.05;
    //- minimum normalised cell determinant
    //- 1 = hex, <= 0 = folded or flattened illegal cell
    minDeterminant 0.001;
    //- minFaceWeight (0 -> 0.5)
    minFaceWeight 0.05;
    //- minVolRatio (0 -> 1)
    minVolRatio 0.01;
    //must be >0 for Fluent compatibility
    minTriangleTwist -1;
    // Advanced
    //- Number of error distribution iterations
    nSmoothScale 4;
    //- amount to scale back displacement at error points
    errorReduction 0.75;
// Advanced
// Flags for optional output
// 0 : only write final meshes
// 1 : write intermediate meshes
// 2 : write volScalarField with cellLevel for postprocessing
// 4 : write current intersections as .obj files
debug 0;
// Merge tolerance. Is fraction of overall bounding box of initial mesh.
// Note: the write tolerance needs to be higher than this.
mergeTolerance 1e-6;
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default        Euler;
gradSchemes
divSchemes
    div(rhoPhi,U)  Gauss upwind;
    div(phi,alpha)  Gauss upwind;
    div(phirb,alpha) Gauss upwind;
laplacianSchemes
    default        linear;
snGradSchemes
    default        corrected;
wallDist
    method meshWave;
FoamFile
    version    2.0;
    format      ascii;
    class      dictionary;
    location    "system";
    object      fvSolution;
solvers
    "alpha.water.*"
        nAlphaCorr      1;
        nAlphaSubCycles 1;
        cAlpha          1;
        MULESCorr      yes;
        nLimiterIter    3;
        tolerance      1e-8;
        relTol          0;
    pcorr
        solver          PCG;
        preconditioner
            tolerance      1e-5;
            relTol          0;
            nPreSweeps      0;
            nPostSweeps    2;
            nFinestSweeps  2;
            mergeLevels    1;
        tolerance      1e-5;
        relTol          0;
        maxIter        50;
    p_rgh
        solver          GAMG;
        tolerance        5e-9;
        relTol          0.01;
        nPreSweeps      0;
        nPostSweeps      2;
        mergeLevels      1;
        maxIter          30;
    p_rghFinal
        $p_rgh;
        tolerance      5e-9;
        relTol          0;
    pcorrFinal
        $pcorr;
        tolerance      5e-9;
        relTol          0;
    "(U|k|epsilon).*"
        nSweeps        1;
        tolerance      1e-6;
        relTol          0.1;
PIMPLE
    nCorrectors        1;
    correctPhi          yes;
    residualControl
        U
                tolerance  1e-4;
                absTol      0;
                relTol      0;
        p_rgh
                tolerance  1e-4;
                absTol      0;
                relTol      0;
        k
                tolerance  1e-3;
                absTol      0;
                relTol      0;
        epsilon
                tolerance  1e-3;
                absTol      0;
                relTol      0;
relaxationFactors
    fields
    equations
        ".*" 1;
Image of mesh: https://imgur.com/a/TP6pI9K
simrego August 13, 2019 03:55
Bad news
Honestly the last guess what i should do is use some relaxation. Or you can try with 0.5 instead of 0.7 which will slows down the simulation a bit. Just try to continue the run from an earlier time step. From 7-8 sec for example, just be far from the diverged step.
relaxationFactors
    equations
        "(U|k|epsilon|omega)" 0.7;
        ".*Final" 1;
I hope it will works. For me this setup is stable even with a trash mesh. :/
And next time if you have a crash, append the end of the log file too. It can contain some useful data.
Nosravi August 13, 2019 03:58
I will make an attempt!
Thank you for your help anyways, I really appreciate it!
vatavuk August 16, 2019 11:19
Hi Mads,
In my experience with interFoam, the Courant number explodes because, at some region and at a certain time, the solver generates very high velocities. You can have a hint on where this region is located by saving the results just before the calculation diverges. Then looking at results you may notice some region with very high velocities.
As I already comented in https://www.cfd-online.com/Forums/op...ver-crash.html , the outlet boundary condition is a possible cause for this problem.
Best Regards,
Paulo
hectorgabriel85 April 15, 2020 12:36
From my experience: OpenFOAM v1812 interFoam is very sensitive to relaxation factors ( relaxationFactors fields equations U pcorr p_rgh). I do not have a definite answer on that.
