foamJob 'pimpleFoam' not found (OpenFOAM-v1812)
Hi everybody.
I have a problem submitting a mpirun mission to the cluster. I have installed openFoam-v1812 in centOS. Now I am trying to do a mpi running on the cluster. I used the command in mpi.sh file Code:
mpirun -v -machinefile $TMPDIR/machines -np 8 /home/cfd06/OpenFOAM/OpenFOAM-v1812/bin/foamJob pimpleFoam -parallel > log.pimpleFoam But if I used the command directly on the shell Code:
mpirun -np 8 pimpleFoam -parallel Update: Well, I solved this error with a new one came. /home/cfd06/OpenFOAM/OpenFOAM-v1812/platforms/linux64GccDPInt64Opt/bin/pimpleFoam: error while loading shared libraries: libmpi.so.1: cannot open shared object file: No such file or directory Does any one have an idea ? I have been fighting for this error for a long time... Thank you! |
When I start openFOAM on our cluster, I have to load the GCC-Compiler and the OpenMPI module before I load OpenFOAM.
Maybe you have to do that as well. Second, depending on you PBS system you run-command can vary from the tutorials. On our cluster the run-command in the script is: mpirun pimpleFoam -parallel > logfile The machine specifications are taken from the PBS script automatically. |
