LES diesel jet
Hi guys,
I'm trying to simulate a diesel jet using LES. I'm trying to run compressibleMultiInterFoam. I think I'm getting close but I keep getting this error: Creating field kinetic energy K Courant Number mean: 0.0020326 max: 2487.28 --> FOAM FATAL ERROR: Different dimensions for = dimensions : [0 2 -1 0 0 0 0] = [1 -1 -1 0 0 0 0] From function bool Foam::dimensionSet::operator=(const Foam::dimensionSet&) const in file dimensionSet/dimensionSet.C at line 171. FOAM aborting Any thoughts??? |
Wrong unit ;) change it the way the solver already told you :D
Thanks.
What file do I need to change though?? |
It looks like the "nut" file
Thanks for that.
So it's wanting me to change the units of the nut file essentially. I wasn't aware the units of that had to change from incompressible to compressible flow? How did you figure out it was nut that needed changing? very interesting... |
Interestingly...
After changing the units of the nut file the error reoccurs: Creating field kinetic energy K Courant Number mean: 0.00020326 max: 248.728 --> FOAM FATAL ERROR: Different dimensions for = dimensions : [1 -1 -1 0 0 0 0] = [0 2 -1 0 0 0 0] From function bool Foam::dimensionSet::operator=(const Foam::dimensionSet&) const in file dimensionSet/dimensionSet.C at line 171. FOAM aborting |
Just because of the units, but I was wrong. You have to change the pressure units when you change from incompressible to compressible to you have to check these.
Yeah I already changed them.
Just to be certain what units for 'p' and 'p_rgh' would you be using? |
p and p_rgh share the same units:
[1 -1 -2 0 0 0 0]; |
yep. thats what i've got them set as. hmmm.... seems like ive missed something else then.
You should look at a tutorial and then compare all the units to yours. Including the thermophysical Properties.
Made a breakthrough of sorts.
Looks like it's "alphat" that needed it's units changed. It runs now. Whether the values I've chosen are physical or not we'll have to see but I've gotten over that issue. |
If you do RANS you should use a wallfunction for alphat with a turbulent Prandlt of 0.85, but if you do a LES with a fine grid it doesnt really matter in my experience.
Edit: I just saw that you are doing LES, so forget about the RANS :) |
