May 28, 2014, 10:59 |
Why is icoFsiFoam considered deprecated?
Rep Power: 12 |
Hello everyone,
I'm working on a biophysically motivated FSI problem and I wonder why the icoFsiFoam solver is deposited in a "deprecatedSolvers" folder. What should be used instead? I'm not talking of course about the particular fluid/solid models, but whether there is now a method/algorithm available that is considered better for some reason? Cheers, N |
February 26, 2015, 08:18 |
Rep Power: 11 |
The same question... Maybe you already know the answer ?
March 5, 2015, 10:00 |
Damon Lee
Rep Power: 11 |
I think that it is considered depreciated because of icoFsiElastciNonLinSolidFoam. From looking at the code it seems that icoFsiFoam doesn't do any loop between solid and liquid within a time step, which might be why they said 'Set up as a fake fluid structure interaction solver' it does:
# include "setPressure.H" # include "solveSolid.H" # include "setMotion.H" # include "solveFluid.H" Code:
do { outerCorr++; # include "setInterfaceDisplacement.H" # include "moveFluidMesh.H" # include "solveFluid.H" # include "setInterfaceForce.H" # include "solveSolid.H" # include "calcFsiResidual.H" } while ( (fsiResidualNorm > outerCorrTolerance) && (outerCorr < nOuterCorr) ); I think that if you want a steady-state solution and only use one core you may aswell use icoFsiFoam. Svensen from the other post I think that you can view it in paraview if for do paraFoam -case fluid. |
[PyFoam] running pyFoam(Plot)Runner.py in parallel | Studi | OpenFOAM Community Contributions | 10 | September 6, 2015 16:38 |
Benchmark for Fluid-Structure Interaction solver (IcoFsiFoam) | Eferal | OpenFOAM | 3 | October 3, 2013 03:04 |
icoFsiFoam in OF1.6-ext does not work | mechy | OpenFOAM | 4 | July 26, 2011 03:14 |
IcofsiFoam not supported under released 141 package | pi06jl6 | OpenFOAM Running, Solving & CFD | 4 | June 26, 2008 13:59 |
Errors in running a icoFsiFoam case | jin_xu | OpenFOAM Pre-Processing | 0 | June 9, 2008 06:48 |
