Rep Power: 0 ![]() |
I have a Simulation of a fan. As stopping criteria I want to calculate the static pressure at a probe over some iterations. I'm using openFOAM v1812. Here my code in controlDict: Code:
functions { probe1 { type probes; libs ("libsampling.so"); writeControl runTime; writeInterval 1; fields (p); probeLocations ( (0.01 -0.15 -1.0) ); } runTimeControl1 { type runTimeControl; libs ("libutilityFunctionObjects.so" "libfieldFunctionObjects.so"); conditions { average1 { type average; functionObject probe1; writeControl runTime; writeInterval 1; fields (p); tolerance 0.2; window 2; } } } Code:
runTimeControl runTimeControl1 output: average: average1 averages: --> FOAM Warning : From function virtual bool Foam::functionObjects::runTimeControls::averageCondition::apply() in file runTimeControl/runTimeCondition/averageCondition/averageCondition.C at line 144 From function object: probe1 Unprocessed fields: p |
Dan Padrao
Rep Power: 7 ![]() |
Did you ever find a solution to this problem? I am currently having a similar problem. Thanks, Dan |
Rep Power: 11 ![]() |
I'm also trying to stop the simulation based on the convergence of a value on a probe point. I'm getting the same error of "Unprocessed field: T" Is there a way to control the convergence of a probe? Thanks, whiteW |
Display Modes | |
Using Probe for part of a patch | ndr | OpenFOAM Running, Solving & CFD | 7 | April 4, 2019 06:26 |
How to probe to create time series plot by probe at dialog | POSTHU | Tecplot | 1 | March 21, 2019 08:31 |
probe Locations error in the dynamicMesh foam extend 4.0 | vahidreza lotfi | OpenFOAM Post-Processing | 2 | August 22, 2018 10:30 |
Empty Probe File - Probes not working | rvmedina20 | OpenFOAM Post-Processing | 3 | May 11, 2016 19:36 |
new atmospheric probe design | manobianco | Main CFD Forum | 0 | May 12, 2012 15:04 |
