November 29, 2017, 09:47 |
Understanding Terms in Compressible pEqn
Rep Power: 8 |
I am trying to understand some of the terms in the compressible version of the pEqn (rhoPimpleFoam) and had some questions that I have not been able to figure out on my own.
My first question has to do with the pressure equation itself. In "Computational Methods for Fluid Dynamics" chapter 10, the pressure-velocity correction is explained as inputting the predicted velocity and density into the continuity equation with a small correction parameter (, ): Where (in OpenFOAM notation) and according to Ferziger In OpenFOAM programming, this is implemented as: Code:
// Calculate flux of HbyA and add contribution from gravity term surfaceScalarField phiHbyA ( "phiHbyA", fvc::interpolate(rho)*fvc::flux(HbyA) + rhorAUf*fvc::ddtCorr(rho, U, phi) + rhorAUf*fvc::interpolate(rho)*(g & mesh.Sf()) ); Code:
// Setup pressure correction equation fvScalarMatrix pDDtEqn ( fvc::ddt(rho) + psi*correction(fvm::ddt(p)) + fvc::div(phiHbyA) == fvOptions(psi, p, rho.name()) ); while (pimple.correctNonOrthogonal()) { fvScalarMatrix pEqn(pDDtEqn - fvm::laplacian(rhorAUf, p)); pEqn.solve(mesh.solver(p.select(pimple.finalInnerIter()))); // Correct velocity flux by (subtracting?) flux from P Equation if (pimple.finalNonOrthogonalIter()) { phi = phiHbyA + pEqn.flux(); } } 1. Why is "fvc::div(phiHbyA) - fvm::laplacian(rhorAUf, P)" is included instead of "phiHbyA - fvm::grad(rhorAUf,P)"? Is there a particular reason the divergence of those terms taken? "(phiHbyA - fvm::grad(rhoAUf,P))*S" should be the correct velocity flux, so taking the divergence seems unnecessary to me. And even if we take the divergence, shouldn't we have to take the divergence of every term in that equation including the 'ddt' terms? 2. Is psi*correction(fvm::ddt(p)) the equivalent term? Or is this simply the density () correction? My second question has to do with how the density is calculated. In rhoPimpleFoam, the density is initially predicted by "rhoEqn.H" prior to calculating the velocity terms: Code:
if (pimple.nCorrPIMPLE() <= 1) { #include "rhoEqn.H" } // --- Pressure-velocity PIMPLE corrector loop while (pimple.loop()) { #include "UEqn.H" #include "EEqn.H" // --- Pressure corrector loop while (pimple.correct()) { if (pimple.consistent()) { #include "pcEqn.H" } else { #include "pEqn.H" } } if (pimple.turbCorr()) { turbulence->correct(); } } Code:
while (pimple.correctNonOrthogonal()) { fvScalarMatrix pEqn(pDDtEqn - fvm::laplacian(rhorAUf, p)); pEqn.solve(mesh.solver(p.select(pimple.finalInnerIter()))); // Correct velocity flux by (subtracting?) flux from P Equation if (pimple.finalNonOrthogonalIter()) { phi = phiHbyA + pEqn.flux(); } } #include "rhoEqn.H" #include "compressibleContinuityErrs.H" Code:
thermo.correctRho(psi*p - psip0, rhoMin, rhoMax) ; rho = thermo.rho(); |
November 29, 2017, 12:54 |
Rep Power: 8 |
In regard to my first question, you can always write the continuity equation in differential form instead of integral form:
If we break it into the (.)* and (.)' terms, we get for the time derivative: and for the divergence term The first term in the time derivative should be "fvc::ddt(rho)" while the second term would then be approximated by "psi*fvm::ddt(p)", where p here is the correction pressure. For the divergence terms, the first term should be "fvc::div(phiHbyA)-fvc::div(laplacian(rhorAUf, p))", but in rhoPimpleFoam, it is written as "fvc::div(phiHbyA)-fvm::div(laplacian(rhorAUf, p))". Why is that? And what about the remaining terms in the divergence term (i.e. all the u' and rho' terms)? I think I am missing something, as I am not sure how the pressure equation is derived in rhoPimpleFoam. |
December 2, 2017, 13:28 |
Rep Power: 8 |
I think I have (semi) figured out my first question. If we re-write the continuity equation as:
Where (*) is the predicted values and (') are the corrected values. We can then break each term down to: But from the definition of , we can rewrite the above equation as: This simply equals (in OpenFOAM notation): Code:
fvc::div(phiHbyA) - fvm::laplacian(rhorAUf,P) Adding all the terms, we get: Code:
fvc::ddt(rho) + psi*correction(fvm::ddt(p)) + fvc::div(phiHbyA) - fvm::laplacian(rhorAUf, p) There doesn't seem to be any additional terms in the OpenFOAM pressure equation to account for this. Is this somehow hidden inside psi*correction(fvm::ddt(p)) and I just don't know? Any help is appreciated. |
February 19, 2018, 12:17 |
Have you been able to solve for the missing term ?
Ahmed Shoeb
Rep Power: 8 |
Hello
thank you for your detailed explanation, have you been able to find a solution to account for the missing term ? Also could you please explain the role of the the fvc::ddtCorr(rho, U, phi) term ? |
October 16, 2018, 10:59 |
Jan Gaertner
Rep Power: 8 |
September 18, 2019, 02:50 |
#6 | |
Kai |
compressible, openfoam, peqn, pressure correction |
Display Modes | |
How rho_ and psi_ are calculated in compressible solvers of OpenFOAM? | JBUNSW | OpenFOAM Programming & Development | 17 | February 12, 2021 09:59 |
Flux discretization of 2D Compressible Navier-Stokes | selig5576 | Main CFD Forum | 7 | March 29, 2017 23:25 |
Simulation of high pressure diesel injector - all phases compressible with cavitation | fivos | CFX | 4 | July 30, 2015 07:48 |
One phase is compressible, can I use compressibleinterfoam? | sharonyue | OpenFOAM Running, Solving & CFD | 2 | March 31, 2014 10:40 |
momentum under-relaxation for compressible flow with SIMPLE | Mihai ARGHIR | Main CFD Forum | 0 | April 7, 2000 05:58 |
