Inconsistent behaviour of function object "scale" |
October 10, 2019, 09:12 |
Sita Drost
Rep Power: 18 |
Hi all,
I've been using velocity ramping to start my OF7 interFoam simulations for a while now, without too much trouble so far. However, in my most recent simulation, OpenFOAM suddenly no longer recognises the keyword "duration" in the "scale" entry in 0/U and fvOptions: Code:
[0] --> FOAM FATAL IO ERROR: [0] Illegal dictionary entry or environment variable name "duration" Valid dictionary entries are 2 ( type start ) Can anyone help me with this? Many thanks, Sita P.S. For sake of completeness, I've also included the contents of my 0/U and fvOptions files below Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: 7 \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format binary; class volVectorField; location "0"; object U; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "../constant/refValues"; dimensions [0 1 -1 0 0 0 0]; internalField uniform (0 0 0); boundaryField { atmosphere { type pressureInletOutletVelocity; value uniform (0 0 0); } inlet { type uniformFixedValue; value $internalField; uniformValue { value (#neg $Uref 0 0); type scale; scale { type quarterSineRamp; start 0; duration $duration; } } } outlet { type outletPhaseMeanVelocity; alpha alpha.water; value $internalField; UnMean { value $Uref; type scale; scale { type quarterSineRamp; start 0; duration $duration; } } } bottom { type symmetryPlane; } side { type symmetryPlane; } midPlane { type symmetryPlane; } hull { type movingWallVelocity; value uniform (0 0 0); } } // ************************************************************************* // Code:
/*--------------------------------*- C++ -*----------------------------------*\ ========= | \\ / F ield | OpenFOAM: The Open Source CFD Toolbox \\ / O peration | Website: https://openfoam.org \\ / A nd | Version: dev \\/ M anipulation | \*---------------------------------------------------------------------------*/ FoamFile { version 2.0; format ascii; class dictionary; location "constant"; object fvOptions; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // #include "refValues"; limitU { type limitVelocity; active yes; selectionMode all; max 50; duration 1000000.0; } velocityRamping { type accelerationSource; active on; selectionMode all; U U; velocity { type scale; scale { type quarterSineRamp; start 0; duration $duration; } value (#neg $Uref 0 0); } } |
October 14, 2019, 08:36 |
Sita Drost
Rep Power: 18 |
Update: by replacing the "duration" keyword in fvOptions in one of my old cases (one that did run) by "banana", I noticed that in the case that's throwing errors, OpenFOAM seems to be looking for "scale" in a different location.
In the working cases OpenFOAM looks in lnInclude/dictionaryTemplates.C, while in my problematic case it looks in db/dictionary/primitiveEntry/primitiveEntry.C Does anyone have any idea what's going wrong here? Many thanks, Sita |
[Other] refineWallLayer Error | Yuby | OpenFOAM Meshing & Mesh Conversion | 2 | November 11, 2021 11:04 |
foamToTecplot360 | thomasduerr | OpenFOAM Post-Processing | 121 | June 11, 2021 10:05 |
How to create a function object in OpenFoam that runs properly ? | mkhm | OpenFOAM Programming & Development | 1 | October 20, 2018 16:16 |
[snappyHexMesh] Problem with parallel run of snappyHexMesh | Lorenzo92 | OpenFOAM Meshing & Mesh Conversion | 5 | April 15, 2016 04:12 |
[blockMesh] BlockMeshmergePatchPairs | hjasak | OpenFOAM Meshing & Mesh Conversion | 11 | August 15, 2008 07:36 |
