tenichols19 |
October 8, 2019 17:09 |
Issues running rhoPimpleFoam
5 Attachment(s)
To start I copied the angledDuct tutorial to my run folder and deleted all files that correspond to the mesh.
I then created my mesh using snappyHexMesh and was able to do so successfully. I ran checkMesh and it checks out.
So to get straight to the problem, when I try and run in parallel
mpirun -np 8 rhoPimpleFoam -parallel
I get an error, which is in the zip file include. file name "parallel error"
When I try and run it in series I get this
\\ / F ield | OpenFOAM: The Open Source CFD Toolbox
\\ / O peration | Website: https://openfoam.org
\\ / A nd | Version: 7
\\/ M anipulation |
Build : 7-6ef561967074
Exec : rhoPimpleFoam
Date : Oct 08 2019
Time : 16:47:44
Host : "taylor-Precision-T1700"
PID : 22253
I/O : uncollated
Case : /home/taylor/OpenFOAM/taylor-7/run/passThrough
nProcs : 1
fileModificationChecking : Monitoring run-time modified files using timeStampMaster (fileModificationSkew 10)
allowSystemOperations : Allowing user-supplied system call operations
Create time
Create mesh for time = 0
PIMPLE: No convergence criteria found
PIMPLE: Corrector convergence criteria found
"(U|k|epsilon)": tolerance 0.0001, relTol 0
Calculations will do 50 corrections if the convergence criteria are not met
PIMPLE: Operating solver in transient mode with 50 outer correctors
Reading thermophysical properties
Selecting thermodynamics package
type hePsiThermo;
mixture pureMixture;
transport sutherland;
thermo hConst;
equationOfState perfectGas;
specie specie;
energy sensibleInternalEnergy;
Reading field U
pressureControl
pMax 150000
pMin 90000
Creating turbulence model
Selecting turbulence model type RAS
Selecting RAS turbulence model kEpsilon
RAS
RASModel kEpsilon;
turbulence on;
printCoeffs on;
Cmu 0.09;
C1 1.44;
C2 1.92;
C3 0;
sigmak 1;
sigmaEps 1.3;
Creating field dpdt
Creating field kinetic energy K
No MRF models present
Creating finite volume options from "constant/fvOptions"
Selecting finite volume options model type explicitPorositySource
Source: porosity1
- selecting cells using cellZone porosity
--> FOAM FATAL ERROR:
Cannot find cellZone porosity
Valid cellZones are 0()
From function void Foam::fv::cellSetOption::setCellSet()
in file cellSetOption/cellSetOption.C at line 142.
FOAM exiting
I have found a similar thread started with this problem but it does help lead me to a solution.
