Water level drop at outlet InterFoam solver
Hi all,
I have some problems using the interfoam solver for my free surface flow through a pipe (which is completely under water) from one water basin to another water basin. I am fairly new to OpenFOAM, so I hope somebody can help me here :) At first, there is not much of a problem, but after some time the water in the second water basin starts to drop. I think that it must have something to do with the outlet boundary conditions. In my case, I am looking for the steady state solution of this flow to calculate some important properties in hydraulic structures. I already have tried a bunch of boundary conditions which seems logical to me, but the problem still occurs (Sometimes only after 90 seconds). I also splitted the outlet boundary in an air and water outlet boundary because of this, but even that eventually doesn't solve it. These are my latest settings; inlet: U: variableHeightFlowRateInletVelocity p_rgh: fixedFluxPressure 0 alpha: variableHeightFlowRate outlet_air: U: fixedValue (0 0.1 0), To avoid air coming in to the model that will push the water down. p_rgh: fixedFluxPressure 0 alpha: inletOutlet 0 outlet_water: U: inletOutlet, inletValue: uniform (0 0 0), value: $internalfield p_rgh: fixedFluxPressure 0 alpha: inletOutlet 1 atmosphere: U: zeroGradient p_rgh: totalPressure uniform 0 alpha: inletOutlet 0 Here are some pictures so you can see what happens after a while: https://imgur.com/a/AL8uPcE Note that water flows in the Y direction. Hope somebody could help me out! Cheers |
Hi!
I have the same problem. Did you solved it somehow? Thank you! Péter |
