October 10, 2019, 05:22 |
Regions not converged
#1 | |
Srikar
Rep Power: 6 |
I am performing a chtMultiRegionSimple foam case and i get the note: "Regions not converged after 20000 iterations." The solution has become stagnant and the residual quite low, still it shows the note at the end. The result looks to have reached saturation at T=3788, from then it gives same values till 20000th iteration. Please find the excerpts from the log file. Kindly help!! Quote:
chtmultiregionsimplefoam, heat transfer, openfoam v5, steadystate |
Initializing transient analysis using static analysis in two-way FSI simulation | Daniel_Khazaei | ANSYS | 50 | September 12, 2017 10:56 |
[CAD formats] Clean / Repair STL file with multiple regions on command line | matthiasd | OpenFOAM Meshing & Mesh Conversion | 6 | May 24, 2016 06:51 |
Determining the calculation sequence of the regions in multe regions calculation | peterhess | OpenFOAM Running, Solving & CFD | 4 | March 9, 2016 03:07 |
chtMultiRegionFoam different properties in (fluid) region(s) | volker1 | OpenFOAM Pre-Processing | 3 | February 4, 2015 06:46 |
New sixDoFRigidBody BC working with laplaceFaceDecomposition | Ya_Squall2010 | OpenFOAM Running, Solving & CFD | 13 | April 17, 2013 02:04 |
