In the same library as groovyBC there is a boundary condition groovyBCDirection that is based on directionMixed |
Respected Sir, Thank you so much for your guidance. I was able to achieve my requirement using groovyBCDirection. Following is what I have done. (May be useful for someone else in future) Code:
floor I have defined somewhere inside my solver code. I was not able to directly use U.component(vector::X) inside the gradient expression. Hence, I defined it as a scalarField and then used it in the boundary condition. @gschaider Sir, Kindly please let me know if I have made any mistake. Thank you once again for your kind help. With Thanks, Pavithra. |
