reactingFoam SandiaD_LTS tutorial error
Hi all. I am using OpenFOAM 6 and I am trying the tutorial SandiaD_LTS. I just use the Allrun file to start the simulation without modifying any parameters. However, there is error for the setFields which shows below.
hi there;
i had the same problem but I could fix it, if you still want fixing the problem I can help:) |
I know, it's a late reply. But incase you need it, you can find the documentation and simulation files for Sandia D flame tutorial
https://www.cemf.ir/reactingfoam-how...e-by-openfoam/ |
Hi;
Thank you very much for you replay, it is very useful thanks again. |
Hello! Could you help me? Having the same problem:confused: Thanks in advance! |
1 Attachment(s)
Dear all. I am using OpenFOAM 7 and I am trying the tutorial SandiaD_LTS without any modification. I just used the Allrun file to start. But I have Floating point exception (core dumped) error after 3719 iteration.
Could you help me? |
"cannot find patchField entry" problems for SandiaD_LTS
Hello everyone, I am new to openfoam and need to simulate nonpremixed combustion in openfoam-9, for this ı select SandiaD_LTS solver
1 .I created axi-symmetric cylinder geometry for 2D case on Salome-Meca 2015, also used seperated small angle (3 degre) wedge planes, 2 .I created patchfiled for inletCH4 (patch), inletair(patch), outlet (patch), frontandBack_pos (wedge) ,frontandBack_neg (wedge) 3. for meshing I used Netgen 2d3d algorithm and 3d parameters hypotheses 4. Exporting .unv mesh file to openfoam 5. I used chemkinToFoam, ideasUnvToFoam, so that constant/polymesh file is appeared, checkMesh is OK , 6. After that, I arranged system/setFieldsDict for initializing inletCH4 field and running reactinFoam, so I encountered the following message; --> FOAM FATAL IO ERROR: Cannot find patchField entry for frontandBack_pos file: /home/ugur/OpenFOAM/ugur-9/run/SandiaD_LTS/0/T/boundaryField from line 25 to line 52. From function void Foam::GeometricField<Type, PatchField, GeoMesh>::Boundary::readField(const Foam::DimensionedField<TypeR, GeoMesh>&, const Foam::dictionary&) [with Type = double; PatchField = Foam::fvPatchField; GeoMesh = Foam::volMesh] in file /home/ubuntu/OpenFOAM/OpenFOAM-9/src/OpenFOAM/lnInclude/GeometricBoundaryField.C at line 184. FOAM exiting about the message, also I selected wedge patch type for frontandBack_pos and frontandBack_neg in constant / polyMesh /boundary 6 ( inletCH4 { type patch; nFaces 7; startFace 64411; } inletair { type patch; nFaces 20; startFace 64418; } outlet { type patch; nFaces 27; startFace 64438; } wallTube { type patch; nFaces 593; startFace 64465; } frontandBack_pos { type patch; nFaces 12980; startFace 65058; } frontandBack_neg { type patch; nFaces 13215; startFace 78038; } ) and, also I selected initial temperature for my boundaryField in 0/T , as like this ; dimensions [0 0 0 1 0 0 0]; internalField uniform 295; boundaryField { inletCH4 { type fixedValue; value uniform 295; } wallTube { type zeroGradient; } inletair { type fixedValue; value uniform 295; } outlet { type zeroGradient; } frontAndBack_pos { type wedge; } frontAndBack_neg { type wedge; } } I feel so helpless and tired. :( Does anyone have a solution for this issue or have encountered this type of problem? Thank you for your help in advance.:) |
Seems that you have a lower case problem there. Your mesh is defined with frontandBack_pos, while your BCs are frontAndBack_pos |
Julio, thanks for attention first of all, You're right, I realized latter. For meshing I used blockMesh utility instead of Salome, Netgen algorithm. Becasuse of this, I annihilated skewness and ortogonality problems. But, ı have a new problem about initial k-epsilon values
For that you check the OF user guide or other regular resources. There are typical calculations for that!
I am facing the same. |
Thank you for letting me know. Could you mention which version seems to work because OpenFOAM v6 did not produce accurate results as mentioned in https://www.cfd-online.com/Forums/op...ad-result.html
I wonder if a particular version produces accurate results. Thank you again |
Thank you for your suggestions! |
