Moving wall not working in multiphaseEulerFoam
Old   January 21, 2023, 18:45
Default Moving wall not working in multiphaseEulerFoam
Jagan Mohan
jagan1mohan is on a distinguished road
Hi FOAMers,
I have asked a part of question in below thread
Experimental verification
Now, I tested following in V10 and ran into issue. It is a very simple task: either there is some fundamental bug in multiphaseEulerFoam solver or I'm making a silly mistake. Perhaps, you can point me in right direction.
A fluidizedBed setup is copied from ../multiphase/multiphaseEulerFoam/RAS/fluidizedBed tutorial folder of V10. Please see Figure (1) in attached image.
All settings are exactly same and only changes are (a) Four sides along X, Z axes are modeled as walls (in original setup, patches along X are modeled as “empty” with one cell thick mesh), (b) setup is run on serial local computer, (c) U.air on walls is changed from “noSlip” to “type fixedValue; uniform (0, 0, 0);”.
As I’m testing “moving–wall” boundary condition, on four sides, a non–zero tangential velocity is imposed. For example, on one of the X walls, it is “type fixedValue; uniform (0, 0, -10);" and on opposite X wall, it is "type fixedValue; uniform (0, 0, 10);". Similarly, on Z walls.
After running for sufficiently long time, U.air and U.particles velocity vector (s) are shown on horizontal slice in Figure (2). This value "10 m/s" in above paragraph is more than gas velocity which is 0.25 m/s. So, expectation is vectors close to the walls are to be aligned along wall. But it is clear that solver is ignoring “moving-wall” boundary condition and they are pointed upwards.
What is going wrong in the setup? I have tried increasing specularityCoefficient to 1.0 (in original setup, it is 0.01) in U.particles but did not see any effect of boundary condition. I can share my setup here, if anyone of you wants to take a look.
Eagerly waiting for your replies.
jagan1mohan is offline   Reply With Quote
boundary condition, bug in openfoam, multiphaseeulerfaom, solver error
Moving wall vs. SRF vs. Moving mesh ghost82 Main CFD Forum 18 February 5, 2022 07:48
[snappyHexMesh] How to draw a 3D-Drawing for Meshing Kahnbein.Kai OpenFOAM Meshing & Mesh Conversion 4 June 15, 2021 12:16
[Commercial meshers] Fluent3DMeshToFoam simvun OpenFOAM Meshing & Mesh Conversion 50 January 19, 2020 15:33
Errors running allwmake in OpenFOAM141dev with WM_COMPILE_OPTION%3ddebug unoder OpenFOAM Installation 11 January 30, 2008 20:30
Convergence moving mesh lr103476 OpenFOAM Running, Solving & CFD 30 November 19, 2007 14:09
