positions file on the latest version of openfoam
Hi all,
I am trying to recreate the solidParticle example from here: https://pingpong.chalmers.se/public/...lication-2.pdf on openFoam v7. I was able to create the solver in the tutorial and compile it without any errors, but unless I am mistaken there is a problem with positions file format: Code:
--> FOAM FATAL IO ERROR: I can only get the solver to run with zero particles. The positions of the two particles are: Code:
2 I have been digging around in the source code all day and can't seem to find where things are read in. The tutorials only contain kinematic particles, where positions are stored in /constant. Any ideas? Thanks |
Maybe I should have asked an alternate question that would also solve this problem. Can anyone explain to me how to find in the deoxygen code where where that file is read in, or what format it should be? I am not a great C++ programmer, and can't seem to figure it out.
Thanks |
Any news on this? I am experiencing the same problem.
Hey,
I never figured out what the issue was, but ended up not needing it. Depending on what your are doing, you might find this function object tutorial useful: https://www.cemf.ir/residence-time-d...ticle-tracing/ It was suggested by someone in another thread I posted and worked well for what I needed. I think there are multiple particle classes, but it seems like the more complex ones can be made into passive tracers with the right settings when running the solver. So if you really need to program something into a solver, I would look at the Lagrangian particle solvers and try grabbing code out of there. That's just an idea though - like I said, I was never successful with that code. Maybe someone with more experience can weigh in... |
Thanks for the reply and the link! I will look into it and see what I can do.
