Curved a Mesh - negative initial temperature error in chtMultiRegionFoam |
Michael
Rep Power: 10 ![]() |
I created a geometry which consists of a pipe that has cool water flowing through it. On the outside of the pipe is a region of hot oil that is flowing across the pipe.
Initially the geometry was created in a rectangular domain. The initial points were created in the xy plane. A second set of points were created by using the same xy coordinates but with a new z-coordinate. I was getting solutions that seemed reasonable and was getting a temperature drop in the oil as it flowed over the pipes. Next I applied a curve to the geometry. So instead of simply extruding the geometry from the xy plane, I rotated the points about an axis (parallel to the y-axis). I also added curved edges between the points on the xy plane to this new rotated plane. Now, the solution is failing to solve and I am getting a negative initial temperature error in the Hot Oil region. Looking at the output, the max/min temperatures in this region don't seem to change much based on the calculations until the end when the minimum swings changes drastically into the negative. I have tried increasing the mesh in the direction of the rotation and in the regions with larger volumes. I have run checkMesh and all the results are reported as "OK". I have changed my surface normal schemes in all regions to account for the decreased orthogonality of the mesh (max of 41 degrees). The only change I made to the boundary condition was to correct the velocity boundary condition (inletOutlet) of the Cool Water which flows out the newly rotated plane. I have also tried tweaking the time steps of the solution and have not seen much variation. |
Peter Hess
Rep Power: 18 ![]() |
Hello!
I made many changes that I do not even remember ![]() At least the negative temperature is now solved. See case update_1 ---------------------------------------------------------------------- The Boundaries in hotOil: AxialEnd1 and AxialEnd2 are defined to be patch. Is that right or they need to be wall? As you defined, the fluid is leaving the regin hotOil through three outlets! I changed those to wall. Like that the fluid is leaving just through one outlet... See case update_2 I did not check the results... Regards Peter Last edited by peterhess; December 8, 2019 at 09:14. |
Michael
Thanks so much! That really helped! I was actually leaving the axial ends open as I am modelling a segment of a circular coiled cooler. I might try changing the axial ends of the hot oil to by a symmetry planes.
Thanks! |
Display Modes | |
[solidMechanics] Support thread for "Solid Mechanics Solvers added to OpenFOAM Extend" | bigphil | OpenFOAM CC Toolkits for Fluid-Structure Interaction | 686 | December 22, 2022 09:10 |
Maximum number of iterations exceeded chtmultiregionsimpleFoam | Moncef | OpenFOAM Running, Solving & CFD | 28 | July 13, 2020 14:26 |
pisoFoam with k-epsilon turb blows up - Some questions | Heroic | OpenFOAM Running, Solving & CFD | 26 | December 17, 2012 03:34 |
Error while running rhoPisoFoam.. | nileshjrane | OpenFOAM Running, Solving & CFD | 8 | August 26, 2010 12:50 |
Convergence moving mesh | lr103476 | OpenFOAM Running, Solving & CFD | 30 | November 19, 2007 14:09 |
