andrewlindsay |
December 8, 2019 22:26 |
OK - I've changed out the fvSchemes file, but now I have another error.
PIMPLE: Iteration 1
Solving for solid region water0
--> FOAM FATAL ERROR:
cannot be called for a calculatedFvPatchField
on patch water0_to_water1 of field h in file "/mnt/c/Users/andre/OneDrive/Documents/openFOAM/FieldJoint/0/water0/h"
You are probably trying to solve for a field with a default boundary condition.
From function Foam::tmp<Foam::Field<Type> > Foam::calculatedFvPatchField<Type>::gradientInternalCoeffs() const [with Type = double]
in file fields/fvPatchFields/basic/calculated/calculatedFvPatchField.C at line 188.
FOAM aborting
#0 Foam::error::printStack(Foam::Ostream&) at ??:?
#1 Foam::error::abort() at ??:?
#2 Foam::calculatedFvPatchField<double>::gradientInternalCoeffs() const at ??:?
#3 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacianUncorrected(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#4 Foam::fv::gaussLaplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvsPatchField, Foam::surfaceMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#5 Foam::fv::laplacianScheme<double, double>::fvmLaplacian(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&) at ??:?
#6 Foam::tmp<Foam::fvMatrix<double> > Foam::fvm::laplacian<double, double>(Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::GeometricField<double, Foam::fvPatchField, Foam::volMesh> const&, Foam::word const&) in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
#7 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
#8 __libc_start_main in "/lib/x86_64-linux-gnu/libc.so.6"
#9 ? in "/opt/openfoam7/platforms/linux64GccDPInt32Opt/bin/chtMultiRegionFoam"
Aborted (core dumped)
Any suggestions on what to do to fix this?
