Restart simulation with different inflow
Hi all! I'm running a simulation with interFoam and I have a (maybe) dumb question. I'm trying to restart a simulation from the 30 second, but using a different inflow rate. I've tried copying the solution from the folder "30" into a folder named "0", changing the initialConditions file in the path "0/include". Nevertheless, the after running the simulation I can't see any change in the results, it's like the flow never increased.
I've looked in forums but the answers I've found are for restarting with the same flow. Can any of you help me please? Thanks in advance! |
you might want to post your files, but initialConditions are the conditions for the first guess at the flow field. You want to change your boundary conditions to increase the flow rate.
Hi Clemente,
I would like to know, why you are copying the results into the 0 folder. You can resume your simulation from the latest time step, by editing your controlDict. As Mr. Bazinga told, you need to change the boundary conditions, to the new flow rate. You can edit your the BCs in the last time step, and continue the simulation from there onwards. |
Hi Krao,
Thanks for your reply. Quote:
I'm doing it just to try something different, originally I just use the LatestTime setting in controlDict. Quote:
To do this I only have to replace the U file, or do I have to do something else? Thank you again!! |
Thank you Bazinga for replying! This are my files:
/*--------------------------------*- C++ -*----------------------------------*\ Code:
FoamFile Code:
/*--------------------------------*- C++ -*----------------------------------*\ As I read from you and Krao, I have to change the last two files in the latestTime that was recorded, right? Thank you again! |
Yes you need to edit the last two files, but I don't think they are required to be replaced.
Assuming that you have a fully developed flow at the latest time step, it is worth to make use of the simulation results obtained so far. So, I would insert the new values into the required part/patch, by editing the files in the required U/K/epsilon/P files in the latest time step folder. Or, if you think that would not make any sense, you can replace and continue. |
ohh that's great! One last thing, there's any way to edit these files if they are written in binary, or do I have to write the results in ascii format only?
thanks again! |
Not required, Binary is ok! But don't open these binary files in standard editors, as it makes the process slow. Use vi editor in your terminal to open and edit these files. Search for the particular patch and edit it. If you are not familiar with Linux terminal use the following link to explore more http://www.wolfdynamics.com/images/O...rash_intro.pdf
1 Attachment(s)
Yes, I'm using Ubuntu actually. The thing is that when I use the vi editor to open these files I get something weird. Attached is an image, maybe I have to use another editor like vim?
What you are getting is absolutely okay, try to search the required patch in the file. For example inlet patch.
1 Attachment(s)
OMG you're right! hahaha I think that I just have to change the "flowRate", right?
Yes :D you are ready to go from here!
Thanks! I really appreciate your help! <3
