Help with (Basic) interFoam simulation
Old   December 12, 2019, 00:51
Default Help with (Basic) interFoam simulation
Nic86 is on a distinguished road
i am trying to run an interFoam turbulent simulation of a channel where water is injected at a specific flow rate.
Unfortunately i am not able to run the model.
Can anyone please review it?
My filed can be downloaded from the following link:
https://wetransfer.com/downloads/12e...2041606/23a77b
Thank you in advance.
Nic
Nic86 is offline   Reply With Quote
Old   December 12, 2019, 05:29
Ben Jankauskas
rhythm is on a distinguished road
Your case is identical to one of the tutorials provided for interFoam, named 'waterChannel'.
The main problem with your case was that the top boundary of the channel was set to a wall BC. interFoam requires an atmospheric pressure boundary condition in order to operate (see the tutorial case).
I have adjusted your case boundary conditions (also had to remesh it in order to specify the atmospheric patch) and it is working now. Note that alpha inlet BC is set to fixedValue 1, however zeroGradient is sufficient as well, given that you initialise the alpha field near it, so the inlet patch should pick up the value.
Case: https://www.dropbox.com/s/hey7bccsnj...ng.tar.gz?dl=0
Cheers,
Ben
rhythm is offline   Reply With Quote
Old   December 13, 2019, 02:37
Wow Ben That's awesome!
I didn't have time today to go through the files but i will check them on Monday.
Thanks for your support: it's really very much appreciated!
This forum is amazing. I couldn't expect a faster answer!
Old   December 27, 2019, 08:51
Hi Ben,
First of all merry belated Xmas.
I finally got some time to look at your revised files and now the simulation runs smoothly. Thanks for that!
I'm now trying to make things more complicated and i'd have a couple of questions if you could be so kind to give me your advice.
1) I'd like to run the model keeping a constant water level at the downstream end of the channel. How would you setup this case? How would you setup it if the downstream end of the channel was full of water and pressurised too?
2) how can I specify the roughness of the walls? In hydraulic applications we normally use a friction coefficient (e.g. Manning ,Gaukler-Strickler , Hazen-Williams and so on). How do you work this out in cfd modelling?
Appreciate your help,
Nic
rising bubble simulation with interFoam cyw OpenFOAM Running, Solving & CFD 17 April 5, 2022 08:12
Water Droplets Entrained within Airflow / Nasal Spray Simulation - Basic Beginner AllyB2106 FLUENT 0 March 27, 2018 20:31
Interfoam... free surface simulation urgent lostin4ever Main CFD Forum 4 October 12, 2010 08:29
three questions regarding interFoam (basic but may confuse many people) Ya_Squall2010 OpenFOAM Programming & Development 0 April 2, 2010 20:07
Basic Poiseuille flow simulation question Ashish Main CFD Forum 0 October 2, 2007 13:05
