-   OpenFOAM Running, Solving & CFD (https://www.cfd-online.com/Forums/openfoam-solving/)
-   -   RhoCentralFoam sudden increase of u and drop of T (https://www.cfd-online.com/Forums/openfoam-solving/222931-rhocentralfoam-sudden-increase-u-drop-t.html)
Friendly December 14, 2019 10:18
I am trying to simulate a supersonic outflow from a pipe into the free environment.
The inlet patch is the beginning of the pipe.
The pipe is convergent and the smallest cross section is the exit.
The outlet is a wide box which resembles the free environment.
The problem arises soon after I start the simulation. Right after the inlet the velocity increases heavily from 0 to 1000 m/s, the temperature drops to almost 0 K,
then even further to negative values which leads to the stop of the simulation.
I think the problem are my BCs. The mesh is easy to generate and has a good quality. The Co-number is 0.2. I am using rhoCentralFoam and openFOAM 4.1.
My boundary conditions are:
for p:
internalField  uniform 1e5;
    inlet
    type            totalPressure;
    gamma          1.4;
    p0              uniform 100e5;
  outlet
        type            waveTransmissive;
        field          p;
        psi            thermo:psi;
        gamma          1.4;
        fieldInf        1e5;
        lInf            1;
        value          uniform 1e5;
    wall
        type            zeroGradient;
for u
internalField  uniform (0 0 0);
inlet
    type            fixedValue;
    value        uniform (0 0 0);
    outlet
        type            inletOutlet;
        inletValue      uniform (0 0 0);
    wall
        type            fixedValue;
for T
internalField  uniform 293.15;
inlet
    type    fixedValue;
    value    uniform 293.15;
    outlet
        type            zeroGradient;
    wall
        type            zeroGradient;
emjay December 14, 2019 19:11
Hello Friendly,
does your inlet condition for the U variable make sense?
Because you specify a totalpressure condition and for u:
inlet
type fixedValue;
this b.c. is like a solid wall. Could you test your U.inlet with zeroGradient?
Friendly December 15, 2019 07:21
Oh yes sry, I copied i from the wrong folder it seems.
Here is my real u inlet:
inlet
type pressureInletOutletVelocity;
