how to accurately simulate flow around cylinder
Like Tree16Likes
Old   May 17, 2013, 04:39
Default how to accurately simulate flow around cylinder
kkpal is on a distinguished road
hi everyone!
I've been doing simulation about flow around cylinder recently.
Some information about the case is listed below.
2D simulation;
U=1, D=1, rho=1, nu=0.01, so Re=100;
domain size: upstream 20D, downstream 40D, topwall and bottom wall 20D.
mesh size: about 40000 vertices
The problem is that no matter how I tried, I can not get the accurate result in terms of strouhal number, which in my case is 1.44. An accurate St for RE100 should be 1.65.
Could someone send me a similar case file which has been verified and yields accurate results so I can check what went wrong in my own case? I will be very grateful!
my email address is kai-zhang-kf@ynu.ac.jp
6863523 and ordinary like this.
kkpal is offline   Reply With Quote
Old   May 17, 2013, 06:41
Sasan Ghomi
sasanghomi is on a distinguished road
Hi ,
I think you use icoFoam as a solver. So I think two parameters have vital role for getting the exact result : 1) discretization method of terms in equations 2)Mesh generation.
So change your fvSchemes and fvSolution as below :
| \\      /  F ield         | OpenFOAM Extend Project: Open Source CFD        |
|  \\    /   O peration     | Version:  1.6-ext                               |
|   \\  /    A nd           | Web:      www.extend-project.de                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSolution;
solvers
    p
        solver           PCG;
        preconditioner   DIC;
        tolerance        1e-06;
        relTol           0;
    U
        solver         BiCG;
        preconditioner   DILU;
        tolerance        1e-05;
        relTol           0;
PISO
   nCorrectors    2;
   nNonOrthogonalCorrectors 0;
    pRefCell        0;
    pRefValue       0;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    object      fvSchemes;
ddtSchemes
    default backward;
gradSchemes
    default         Gauss linear;
    grad(p)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss GammaV 0.5 ;
laplacianSchemes
    default         Gauss linear limited 0.5;
    laplacian(nu,U) Gauss linear limited 0.5;
    laplacian(rUA,pcorr) Gauss linear limited 0.5;
    laplacian(rAU,p) Gauss linear limited 0.5;
interpolationSchemes
    default         linear;
    interpolate(HbyA) linear;
snGradSchemes
    default         limited 0.5;
fluxRequired
    default         no;
    pcorr;
    p;
Hope this helps,
Sasan.
hua1015, firat, Mehrez and 4 others like this.
sasanghomi is offline   Reply With Quote
Old   May 17, 2013, 10:55
dear sasan
thanks very much! your post solved the problem, I used icoFoam this time, now my St number is 1.62, which is much better than the previous ones. Now it is clear that it is not the problem of my mesh, but the discretization method of terms in equations that is giving me bad results.
However, in my previous simulations, I used pimpleFoam because for the long run I need to do much higher Re simulations, for which icoFoam is not appropriate.
Here is my fvschemes and fvsolutions, which is for pimpleFoam and did not give right result.
|  \\    /   O peration     | Version:  2.1.x                                 |
|   \\  /    A nd           | Web:      www.OpenFOAM.org                      |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSolution;
solvers
    p
        solver          GAMG;
        tolerance       1e-06;
        relTol          0.01;
        smoother        GaussSeidel;
        cacheAgglomeration true;
        nCellsInCoarsestLevel 10;
        agglomerator    faceAreaPair;
        mergeLevels     1;
    pFinal
        solver          GAMG;
        tolerance       1e-06;
        relTol          0;
        mergeLevels     1;
    "(U|k|epsilon)"
        solver          PBiCG;
        tolerance       1e-05;
        relTol          0.1;
    "(U|k|epsilon)Final"
        $U;
        tolerance       1e-05;
        relTol          0;
PIMPLE
    nOuterCorrectors 1;
    nCorrectors     2;
    pRefCell        0;
    pRefValue       0;
relaxationFactors
    fields
    equations
        "U.*"           0.9;
        "k.*"           1;
        "epsilon.*"     1;
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      fvSchemes;
ddtSchemes
    default         Euler;
gradSchemes
    grad(U)         Gauss linear;
divSchemes
    default         none;
    div(phi,U)      Gauss limitedLinearV 1;
    div(phi,k)      Gauss limitedLinear 1;
    div(phi,epsilon) Gauss limitedLinear 1;
    div(phi,R)      Gauss limitedLinear 1;
    div(R)          Gauss linear;
    div(phi,nuTilda) Gauss limitedLinear 1;
    div((nuEff*dev(T(grad(U))))) Gauss linear;
laplacianSchemes
    default         none;
    laplacian(nuEff,U) Gauss linear corrected;
    laplacian((1|A(U)),p) Gauss linear corrected;
    laplacian(DkEff,k) Gauss linear corrected;
    laplacian(DepsilonEff,epsilon) Gauss linear corrected;
    laplacian(DREff,R) Gauss linear corrected;
    laplacian(DnuTildaEff,nuTilda) Gauss linear corrected;
    default         linear;
    interpolate(U)  linear;
snGradSchemes
    default         corrected;
fluxRequired
    default         no;
    p               ;
It seems that settings in pimpleFoam is much more complex than those in icoFoam, can you guide me how to make adjustment to these files?
Old   May 17, 2013, 11:56
I just tried changing the settings in pimpleFoam to the ones you provided, hoping that it would also give good result, but it did not.
It seems in my case ,icoFoam does a better job than pimpleFoam.
or pimpleFoam requires something other different settings?
Old   May 17, 2013, 12:36
dear sasan
I think I found the cause for the inaccuracy of the Str number in pimpleFoam.
HTML Code:
http://www.cfd-online.com/Forums/openfoam-solving/94785-icofoam-vs-pisofoam-laminar.html
in this thread it is noted that relaxation may affect the Str number. So I removed the relaxation parameters and magically the good result came out!! Though I don't know what is the particular reason for this improvement.
it is found out that for unsteady cases relaxation is more than necessary. however, in pimpleFoam relaxation is allowable, should we never use relaxation in pimpleFoam when dealing with unsteady cases?
nimasam likes this.
Old   May 17, 2013, 15:31
Sasan Ghomi
Hi kia ,
You are welcome .
I tried to simulate turbulent flow around a cylinder with pisoFoam 6-7 month ago.But I had some problems and the case didn't converge and amplitude of Lift didn't get a fix value(oscillation was not regular ). Actually I didn't succeed to simulate the flow accurately.
About relaxation factor I should say that I have heard when you use PISO algorithm for solving equations if you use relaxation factor only final result (after convergence) is accurate.
Anyway I am interested in simulation of turbulent flow around a cylinder and I will try to do it.
Let me know your progress.
Thanks and best regards,
Sasan.
Old   September 20, 2013, 16:27
Default Help
You
sherandlock is on a distinguished road
Hi Sasan,
Thank you for your help very much.
This is my error. When time is 1.45s. I have no idea why this is happenning, Would you like to enlighten me a little bit?
Courant Number mean: 1.11225e+91 max: 2.80651e+96
#0 Foam::error:rintStack(Foam::Ostream&) in "/home/yzhou/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/lib/libOpenFOAM.so"
#1 Foam::sigFpe::sigHandler(int) in "/home/yzhou/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/lib/libOpenFOAM.so"
#2 __restore_rt at sigaction.c:0
#3 Foam::PBiCG::solve(Foam::Field<double>&, Foam::Field<double> const&, unsigned char) const in "/home/yzhou/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/lib/libOpenFOAM.so"
#4 Foam::fvMatrix<Foam::Vector<double> >::solve(Foam::dictionary const&) in "/home/yzhou/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/bin/icoFoam"
#5 Foam::fvMatrix<Foam::Vector<double> >::solve() in "/home/yzhou/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/bin/icoFoam"
#6 main in "/home/yzhou/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/bin/icoFoam"
#7 __libc_start_main in "/lib64/libc.so.6"
#8 Foam::UOPstream::write(char) in "/home/yzhou/OpenFOAM/OpenFOAM-2.1.1/platforms/linux64Gcc44DPOpt/bin/icoFoam"
Floating exception
sherandlock is offline   Reply With Quote
Old   September 20, 2013, 17:37
Sasan Ghomi
Hi sherandlock ,
Your case has diverged . The Courant number is very high . So I only have one idea ,
Try to use adjustTimeStep in the controlDict. Add below lines in the controlDict :
adjustTimeStep  yes;
maxCo           0.5;
maxDeltaT       0.01;
Hope this helps.
m5m5kh likes this.
Old   February 26, 2014, 11:56
Default flow past a circular cylinder
ok
Maimouna is on a distinguished road
Dear Sasan,
I'm try to implement flow past circular cylinder in pimpleFoam solver. I attached the case that I'm looking for (pdf file). I blocked and checked mesh everything was fine. I run the case without any problem. But, when I plotted drag and lift forces (using Matlab), it gave me inconvenience result. I don't know where is my mistake.
Anyway, I attached my case if you could please go through all files and checked please what are my mistakes.
NT: D = 1, Re = 100. I'm trying to fix nu in transportProperties file and change u in the attached file because I didn't know where are my errors so I'm trying to do different ways. Also, might blockMeshDict affects my results if you could check please.
Many thanks in advanced.
Maimouna is offline   Reply With Quote
Old   February 28, 2014, 08:36
Sasan Ghomi
There is no attached file, honestly!
best regards.
Old   February 28, 2014, 08:45
ok
Hi Sasan,
sorry, I attached them again.
Looking forward for your help.
Old   March 3, 2014, 21:24
I think at Re=100, turbulence model will jeopardize your result. In this regime the flow is mainly 2 dimensional and could be regarded as not turbulent.
Originally Posted by Maimouna View Post
Dear Sasan,
Old   March 4, 2014, 05:00
ok
Dear Kai Zhang,
I'm working in laminar not turbulence model.
Have I changed my solver from pimpleFoam to another solver or that does not affect?
What other changes would be supposed?
Regards
Old   March 4, 2014, 05:17
Alexey Matveichev
alexeym has a spectacular aura aboutalexeym has a spectacular aura about
Send a message via Skype™ to alexeym
According to your case files, you're working with oneEqEddy LES model for the turbulence. If you'd like to run simulation for laminar case you need to:
1. Put RASModel in constant/turbulenceProperties
2. Put
RASModel        laminar;
turbulence      off;
printCoeffs     on;
in constant/RASProperties.
Also I'd suggest you to change fvSolution:
PIMPLE
    nOuterCorrectors 10;
    nCorrectors     2;
    pRefCell        0;
    pRefValue       0;
    residualControl
        "(U|p)"
             tolarance 1e-4;
             relTol 0;
to be sure that you have converged solution on every time step.
alexeym is offline   Reply With Quote
Old   March 4, 2014, 05:51
ok
Dear Alexey,
many thanks for your reply. I did all changes that you supposed. After typing pimpleFoam in the command window, I got this error
[QUOTE]
| \\ / F ield | foam-extend: Open Source CFD |
| \\ / O peration | Version: 3.0 |
| \\ / A nd | Web: http://www.extend-project.de |
Build : 3.0-8d34057e525d
Exec : pimpleFoam
Date : Mar 04 2014
Time : 10:40:09
Host : maimouna-desktop
PID : 3105
CtrlDict : /home/maimouna/foam/foam-extend-3.0/etc/controlDict
Case : /home/maimouna/foam/foam-extend-3.0/tutorials/incompressible/pimpleFoam/circularCylinderModified
nProcs : 1
SigFpe : Enabling floating point exception trapping (FOAM_SIGFPE).
Create time
Create mesh for time = 0.000000e+00
Reading field p
Reading field U
Selecting incompressible transport model Newtonian
Selecting turbulence model type RASModel
Selecting RAS turbulence model laminar
--> FOAM FATAL IO ERROR:
keyword turbulence is undefined in dictionary "/home/maimouna/foam/foam-extend-3.0/tutorials/incompressible/pimpleFoam/circularCylinderModified/constant/RASProperties"
file: /home/maimouna/foam/foam-extend-3.0/tutorials/incompressible/pimpleFoam/circularCylinderModified/constant/RASProperties from line 18 to line 82.
From function dictionary::lookupEntry(const word&, bool, bool) const
in file db/dictionary/dictionary.C at line 395.
FOAM exiting
maimouna@maimouna-desktop:~/foam/foam-extend-3.0/tutorials/incompressible/pimpleFoam/circularCylinderModified$
What does this error mean?
Old   March 4, 2014, 05:56
Alexey Matveichev
Well,
Post your RASProperties file, otherwise I can only suggest that RASProperties file is incorrect
Old   March 4, 2014, 06:01
ok
This is RASProperties file
| \\ / O peration | Version: 1.6 |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "constant";
object RASProperties;
RASModel laminar; //oneEqEddy;
delta cubeRootVol;
printCoeffs on;
cubeRootVolCoeffs
deltaCoeff 1;
PrandtlCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Cdelta 0.158;
vanDriestCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Aplus 26;
Cdelta 0.158;
smoothCoeffs
delta cubeRootVol;
cubeRootVolCoeffs
deltaCoeff 1;
maxDeltaRatio 1.1;
Regards
Old   March 4, 2014, 06:06
Alexey Matveichev
Well, can you please tell me the difference between what you've posted and what I've suggested to put into RASProperties?
Can you create a file with just
|  \\    /   O peration     | Version:  2.2.2                                 |
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
RASModel        laminar;
turbulence      off;
printCoeffs     on;
The error you've got tells you that there's no turbulence keyword in RASProperties files, and in fact there's no such keyword in your file.
Old   March 4, 2014, 06:11
ok
Dear Alexey,
sorry for that mistakes.
I is running now. I will let you know about the result.
Many thanks
Old   March 4, 2014, 06:36
ok
Dear Alexy,
the running is done.
I have two questions please
1. in cotrolDict file (attached)
startTime 0;
endTime 25.0;
deltaT 0.01;
but the running is completed after 1.4, why?
FoamFile
    version     2.0;
    format      ascii;
    class       dictionary;
    location    "system";
    object      controlDict;
application     pimpleFoam;
startFrom       latestTime;
startTime       0;
stopAt          endTime;
endTime         25.0;
deltaT          0.01; //1e-04
writeControl    adjustableRunTime;
writeInterval   0.1; //5.0e-1
purgeWrite      0;
writeFormat     binary;
writePrecision  6;
writeCompression uncompressed;
timeFormat      scientific;
timePrecision   6;
runTimeModifiable yes;
adjustTimeStep    yes;
maxCo             0.5;
maxDeltaT         2.0e-3;
functions
    probes
        type            probes;
        functionObjectLibs ("libsampling.so");
        enabled         true;
        outputControl   timeStep;
        outputInterval  1;
        probeLocations
            ( 0.05   0.0   0.002 )
            ( 0.05   0.01  0.002 )
            ( 0.05   0.01  0.002 )
            ( 0.05   0.01  0.002 )
            ( 0.05   0.01  0.002 )
            ( 0.05   0.01  0.002 )
            ( 0.05   0.01  0.002 )
        fields
            p
    forces
        type        forceCoeffs;
        functionObjectLibs ( "libforces.so" );
        outputInterval 1;
        patches
            walls
            directForceDensity no;
        pName       p;
        UName       U;
        rhoName     rhoInf;
        //log         true;
        rhoInf      994.5;
        CofR        ( 0 0 0 );
        liftDir     ( 0 1 0 );
        dragDir     ( 1 0 0 );
        pitchAxis   ( 0 0 1 );
        magUInf     1.787e-4; //1; //0.54
        lRef        0.04;
        Aref        0.0157;
        Aref1        0.004;
        rhoRef      994.5;
    fieldAverage1
        type            fieldAverage;
        functionObjectLibs ("libfieldFunctionObjects.so");
        enabled         true;
        outputControl   outputTime;
        fields
            U
                mean        on;
                prime2Mean  on;
                base        time;
            p
                mean        on;
                prime2Mean  on;
                base        time;
2. the drag chart is given as attached. Why? I know the drag coefficient figure is tottaly different, whats the wrong?
Best regards
[Other] OpenFoam Flow over a Circular Cylinder WolfgangS. OpenFOAM Meshing & Mesh Conversion 12 March 3, 2014 10:53
benchmark: flow over a circular cylinder goodegg Main CFD Forum 12 January 22, 2013 11:47
Particle deposition on circular cylinder in turbulent flow Julian K. CFX 1 October 3, 2011 17:51
flow around a cylinder pXYZ Main CFD Forum 14 July 25, 2011 10:05
Flow induced vibration of a mobile cylinder Hooman Main CFD Forum 0 December 31, 2010 08:48
