usr0830 |
January 8, 2020 04:55 |
Very low Courant numbers for multiple AMI
2 Attachment(s)
I am studying the interaction of 2 rotors using cyclic AMI with pimpleFoam. The wind velocity is 10m/s and the rotor has a high rotational speed of 1200 rpm.
The maximum Courant number is set at 0.7. The smallest theoretically calculated time step size for this Courant number is 1e-5 and the largest is 1e-3. The simulations never reach these time step sizes. They oscillate around 1e-7 and 1e-6.
When I map the Courant number obtained from OpenFOAM, I see that in the outer domain, where the cells are comparatively larger than inside the rotor region, the courant number values are very small (in the order of e-5). The velocity in this region is initialised at 10 m/s (Figure2). So, I expected higher Courant numbers here.
The problem here, in my opinion, is that these low Co values are causing the time step sizes to be very small and hence slowing the simulation down drastically. There also seems to be a small jump in the Co at the interface between the stationary and the rotating parts. (Shown in Fig1)
Could anybody please help me understand why the Co is so low in the outer domain?
Is there a way to set a minimum Courant number for the simulations?
I have attached a few set-up files which might give some insight into the issue.
Thanks in advance.
Controldict file
| \\ / O peration | Version: 2.2.2 |
| \\ / A nd | Web: www.OpenFOAM.org |
| \\/ M anipulation | |
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object controlDict;
application pimpleFoam;
startFrom latestTime;
startTime 0;
stopAt endTime;
//stopAt nextWrite;
//stopAt noWriteNow
endTime 2;
deltaT 1e-5;
writeControl adjustableRunTime;
writeInterval 0.1;
purgeWrite 0;
writeFormat ascii;
writePrecision 9;
writeCompression off;
timeFormat general;
timePrecision 6;
runTimeModifiable true;
adjustTimeStep yes;
maxCo 0.7;
functions
forces_t1
type forces;
functionObjectLibs ("libforces.so");
patches (blades1 blades2);
origin (0.0 0.0 0.5);
coordinateRotation
type axesRotation;
e3 (0 0 1);
e1 (1 0 0);
rho rhoInf;
rhoInf 1.225;
writeInterval 0.00001;
forces_t2
type forces;
patches (blades3 blades4);
origin (0.0 0.65 0.5);
coordinateRotation
type axesRotation;
e3 (0 0 1);
e1 (1 0 0);
rho rhoInf;
rhoInf 1.225;
Co1
type CourantNo;
libs ("libfieldFunctionObjects.so");
executeControl timeStep;
executeInterval 1;
writeControl writeTime;
fvSchemes
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSchemes;
ddtSchemes
//default Euler;
default CrankNicolson 0.5;
gradSchemes
default Gauss linear;
grad(p) Gauss linear;
grad(U) cellLimited Gauss linear 1;
divSchemes
default none;
div(phi,U) Gauss linearUpwindV grad(U);
div(phi,nuTilda) Gauss upwind;
div((nuEff*dev2(T(grad(U))))) Gauss linear;
laplacianSchemes
default Gauss linear corrected;
interpolationSchemes
default linear;
snGradSchemes
default corrected;
fluxRequired
default no;
pcorr ;
p ;
wallDist
method meshWave;
fvSolution
FoamFile
version 2.0;
format ascii;
class dictionary;
location "system";
object fvSolution;
solvers
pcorr
solver GAMG;
smoother GaussSeidel;
nPreSweeps 0;
nPostSweeps 2;
cacheAgglomeration off;
agglomerator faceAreaPair;
nCellsInCoarsestLevel 10;
mergeLevels 1;
tolerance 0.001;
relTol 0;
p
$pcorr;
tolerance 1e-06;
relTol 0.01;
pFinal
$p;
tolerance 1e-06;
relTol 0;
// Phi
// solver GAMG;
// smoother DIC;
// tolerance 1e-06;
// relTol 0.01;
"(U|nuTilda)"
solver smoothSolver;
tolerance 1e-05;
relTol 0.1;
"(U|nuTilda)Final"
$U;
tolerance 1e-06;
relTol 0;
potentialFlow
nNonOrthogonalCorrectors 2;
SIMPLE
nNonOrthogonalCorrectors 0;
pRefCell 0;
pRefValue 0;
PIMPLE
correctPhi no;
nOuterCorrectors 1;
nCorrectors 2;
nNonOrthogonalCorrectors 5;
pRefCell 0;
pRefValue 0;
relaxationFactors
"(U|nuTilda).*" 1;
cache
grad(U);
boundary
FoamFile
version 2.0;
format ascii;
class polyBoundaryMesh;
location "constant/polyMesh";
object boundary;
13
blades1
type wall;
inGroups 1(wall);
nFaces 99;
startFace 36323;
blades2
type wall;
inGroups 1(wall);
nFaces 99;
startFace 36422;
blades3
type wall;
inGroups 1(wall);
nFaces 99;
startFace 36521;
blades4
type wall;
inGroups 1(wall);
nFaces 99;
startFace 36620;
bottom
type symmetryPlane;
nFaces 39;
startFace 36719;
ext_interface1
type cyclicAMI;
nFaces 38;
startFace 36758;
matchTolerance 0.025;
transform noOrdering;
neighbourPatch int_interface1;
method faceAreaWeightAMI;
ext_interface2
type cyclicAMI;
nFaces 38;
startFace 36796;
neighbourPatch int_interface2;
inlet
type patch;
nFaces 39;
startFace 36834;
int_interface1
type cyclicAMI;
nFaces 38;
startFace 36873;
neighbourPatch ext_interface1;
int_interface2
type cyclicAMI;
nFaces 38;
startFace 36911;
neighbourPatch ext_interface2;
outlet
type patch;
nFaces 39;
startFace 36949;
sides
type empty;
inGroups 1(empty);
nFaces 45204;
startFace 36988;
top
type symmetryPlane;
nFaces 39;
startFace 82192;
