Defining a Heat Source in OpenFOAM v2112 for chtMultiRegionTwoPhaseulerFoam |
March 29, 2022, 15:33 |
Rep Power: 4 |
Hi Everyone,
I'm attempting to run some simulations of a heater submerged in water using OpenFOAM v2112 and chtMultiRegionTwoPhaseEulerFoam. My simulations runs without error but it appears my heat source region is not producing any heat flux. Having compared the heat transfer tutorials which use a heater region in OpenFOAM9 to OpenFOAM v2112, they do not seem to use the same approach, which has caused my confusion. Shown below is my unsuccessful attempt to produce a working heat source, would anyone please be able to advise me about how I can produce a heat source using OpenFOAM v2112 and chtMultiRegionTwoPhaseEulerFoam. Thank you in advance for your time and help. NOTE: The below code is from 0/heater/T Code:
FoamFile { version 2.0; format ascii; class volScalarField; object T; } // * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * * // dimensions [ 0 0 0 1 0 0 0 ]; internalField uniform 933; boundaryField { //#includeEtc "caseDicts/setConstraintTypes" walls { type zeroGradient; } heater_to_fluid { type compressible::turbulentTemperatureTwoPhaseRadCoupledMixed; active true; mode flux; q uniform 209143.8; value $internalField;//1123 Tnbr T.liquid; kappaMethod solidThermo; region solid; // Name of the other phase in the flid region mixing with 'liquid' phase otherPhase gas; qrNbr none; qr none; } } |
[swak4Foam] swak4foam for OpenFOAM 4.0 | mnikku | OpenFOAM Community Contributions | 80 | May 17, 2022 08:06 |
[foam-extend.org] Problems installing foam-extend-4.0 on openSUSE 42.2 and Ubuntu 16.04 | ordinary | OpenFOAM Installation | 19 | September 3, 2019 18:13 |
centOS 5.6 : paraFoam not working | yossi | OpenFOAM Installation | 2 | October 9, 2013 01:41 |
Question about heat transfer coefficient setting for CFX | Anna Tian | CFX | 1 | June 16, 2013 06:28 |
friction forces icoFoam | ofslcm | OpenFOAM | 3 | April 7, 2012 10:57 |
