mpirun -np error
Old   January 28, 2020, 05:53
Default mpirun -np error
Ilhwan Yeo
jayson is on a distinguished road
hello
I am a mew FOAM user. I have a some problem.
This is error message.
I did connect all nodes and shared OpenFOAM-v1912 files.
please help me.
[2phase@knl001 depthCharge3D]$ mpirun -hostfile machines.txt -np 60 -compressibleInterFoam -parallel
Open MPI has detected that a parameter given to a command line
option does not match the expected format:
Option: np
Param: -parallel
This is frequently caused by omitting to provide the parameter
to an option that requires one. Please check the command line and try again.
jayson is offline   Reply With Quote
Old   January 28, 2020, 17:53
Svetlana Tkachenko
Svetlana is on a distinguished road
Remove the '-' before 'compressibleInterFoam' ?
Svetlana is offline   Reply With Quote
Old   January 28, 2020, 19:26
Ilhwan Yeo
Thank you! but, another error message comes out
bash: orted: command not found
ORTE was unable to reliably start one or more daemons.
This usually is caused by:
* not finding the required libraries and/or binaries on
one or more nodes. Please check your PATH and LD_LIBRARY_PATH
settings, or configure OMPI with --enable-orterun-prefix-by-default
* lack of authority to execute on one or more specified nodes.
Please verify your allocation and authorities.
* the inability to write startup files into /tmp (--tmpdir/orte_tmpdir_base).
Please check with your sys admin to determine the correct location to use.
* compilation of the orted with dynamic libraries when static are required
(e.g., on Cray). Please check your configure cmd line and consider using
one of the contrib/platform definitions for your system type.
* an inability to create a connection back to mpirun due to a
lack of common network interfaces and/or no route found between
them. Please check network connectivity (including firewalls
and network routing requirements).
Old   January 28, 2020, 19:48
Svetlana Tkachenko
From this thread ([OMPI users]) environment variables need to be set in bashrc for non-interactive logins, e.g. at the top of the bashrc file. Do you have this?
Mike also gave helpful troubleshooting tips at this forum post.
Old   January 28, 2020, 20:44
Ilhwan Yeo
thanks.
what means about "non-interactive logins"? I installed OF in shared home.
and I set correct path..
Old   January 28, 2020, 21:24
Svetlana Tkachenko
1. Are all processes expected to run on the same computer or on different ones? If on different ones, the child processes will need to log in to the remote computer without you. This is not interactive.
2. How did you set the path?
Thanks,
Old   January 28, 2020, 22:02
Ilhwan Yeo
Thanks,
I just write these.
export PATH=$PATH:/usr/local/opt/openmpi/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/usr/local/opt/openmpi/lib
but I installed openmpi-1.10.7 in Thrid party-v1912. so do I write the path differently?
for example,
export PATH=$PATH:/home/2phase/OpenFOAM/ThridParty-v1912/openmpi-1.10.7/bin
export LD_LIBRARY_PATH=$LD_LIBRARY_PATH:/home/2phase/OpenFOAM/ThridParty-v1912/openmpi-1.10.7/lib
hanks for your help
Old   January 28, 2020, 22:59
Svetlana Tkachenko
I would suggest to put these two lines at the top (not at the bottom) of your bashrc.
Old   January 28, 2020, 23:04
Ilhwan Yeo
I put two lines at the top in baschrc whicn located in OpenFOAM-v1912/etc.
but the same error message comes out..
thank you
Old   January 30, 2020, 20:10
Svetlana Tkachenko
I would suggest to follow Mike's troubleshooting steps which I linked earlier, and post the results here.
Old   April 25, 2021, 08:05
cyou
cyou is on a distinguished road
So, finally, how did you solve this problem?
cyou is offline   Reply With Quote
[blockMesh] blockMesh with double grading. spwater OpenFOAM Meshing & Mesh Conversion 92 January 12, 2019 09:00
DPM udf error haghshenasfard FLUENT 0 April 13, 2016 06:35
[swak4Foam] GroovyBC the dynamic cousin of funkySetFields that lives on the suburb of the mesh gschaider OpenFOAM Community Contributions 300 October 29, 2014 18:00
OpenFOAM without MPI kokizzu OpenFOAM Installation 4 May 26, 2014 09:17
DecomposePar links against liblamso0 with OpenMPI jens_klostermann OpenFOAM Bugs 11 June 28, 2007 17:51
