My simulations don't scale when I use multiple nodes -help
Old   February 11, 2020, 17:47
Default My simulations don't scale when I use multiple nodes -help
KTG
Abe
KTG is on a distinguished road
Hey all,
I am having some sort of issue where I am observing a speedup in my simulations as I add more cores within one node, but as soon as I go to two nodes, there is no increase. I can't find any info on this - I tried the -bind-to core mpi flag, but no luck. Has anyone observed this behavior of openFoam on a cluster, or have any ideas about how to fix it? I am using openMPI and SLURM, so I call the solver this way:
mpirun -np $SLURM_NTASKS pimpleFoam -parallel > log
I am using a cluster running centos with these specs:
  • 144 Dual Socket-Six Core Nodes
  • 2.8 GHz Intel Xeon (Westmere X5660) processors
  • RAM:
    • 24 Gbytes memory per node (2 Gbytes per processor core) on most nodes
  • Mellanox QDR Infiniband interconnect
  • Gigabit Ethernet interconnect for management
I was thinking the issue had to do with a bottleneck? Is there a way to check that its actually using the Infiniband ? Any ideas welcome!
Thanks-
KTG is offline   Reply With Quote
Old   February 11, 2020, 23:09
HPE
HPE's Avatar
Herpes Free Engineer
HPE is on a distinguished road
how many cells - how many cores?
HPE is offline   Reply With Quote
Old   February 18, 2020, 21:00
KTG
Abe
sorry for the delay! It seems that CFD forums doesn't send me e-mails anymore...
Last time I was playing with it, I used over 5 million cells, with 64 cores vs. 32, and got was appears to be the same result. Before I though it was a bottle neck issue, but for all I know the first node is doing all the work. I also notice that the averaging function object is taking an insanely long time, which may or may not be related.
Thanks for the reply!
Old   March 4, 2020, 22:26
KTG
Abe
I was thinking maybe the MPI is throwing 64 jobs to the first 32 cores and multi-threading it? Does anyone know if there is a way to track the hardware that works on each processor directory / any way to get more information out of of the cluster about what is going on?
Launching multiple CFD simulations in parallel on cluster jthornton232 OpenFOAM Programming & Development 0 August 14, 2019 20:53
Fine/Marine parallel computation on multiple nodes inarus Fidelity CFD 2 February 24, 2015 07:38
MPI code on multiple nodes, scalability and best practice t.teschner Hardware 0 October 7, 2014 05:07
Can I scale up from 1 to 2 nodes with mixed CPU? pongup Hardware 2 April 14, 2014 15:50
Running in parallel on multiple nodes kalyangoparaju OpenFOAM 5 January 18, 2012 11:36
