February 15, 2020, 04:44 |
Reynolds Stress model in 2D flows
Agustín Villa
Rep Power: 15 |
I recently wanted to test the Reynolds Stress models of OpenFOAM on different channel flows in 2D flows as I have done for V&V of eddy viscosity models. My surprise came up when their performance was dissapointing. Velocity is underestimated by far! What I have also seen is that for 2D simulations, the Rzz stress tensor component is also resolved (while Uz is not). Do you think that could affect as well to the solution. Are these models only developed for 3D simulations? Thank you in advance for your answer! PS: please see in attachment the uPlus velocity for a Re_tau=395 channel flow |
February 15, 2020, 06:05 |
Herpes Free Engineer
Rep Power: 12 |
Please refer below for others to replicate your issue.
The OpenFOAM community is the biggest contributor to OpenFOAM: User guide/Wiki-1/Wiki-2/Code guide/Code Wiki/Journal Nilsson/Guerrero/Holzinger/Holzmann/Nagy/Santos/Nozaki/Jasak/Primer Governance Bugs/Features: OpenFOAM (ESI-OpenCFD-Trademark) Bugs/Features: FOAM-Extend (Wikki-FSB) Bugs: OpenFOAM.org How to create a MWE New: Forkable OpenFOAM mirror |
February 15, 2020, 07:23 |
Agustín Villa
Rep Power: 15 |
I attach the test case to be run with simpleFoam (first please use blockMesh). There is a python script to he run from the case folder Code:
python3 python/plotUPlus.py https://drive.google.com/open?id=1D2...Bt7ptt3OfUkzuA Last edited by agustinvo; February 15, 2020 at 09:41. |
February 15, 2020, 09:00 |
Rep Power: 12 |
I think youve forgotten to attach it.
February 15, 2020, 09:41 |
Agustín Villa
Rep Power: 15 |
Thank you! Now it should be available via Google Drive
February 15, 2020, 16:10 |
Rep Power: 12 |
I havent run ur case yet; however, noticed that your y1+ is less than 1. LRR is, as far as I know, a high Reynolds number turbulence model, that is, below the onset of inertial layer is not formulated by LRR. You may need to go for a new grid where the first wall normal grid point is within the inertial sublayer, and to use a set of wall functions.
Also I still need to verify that your setup actually reflects ReTau=395, and your normalisation is correct. Sometimes, these become tricky even though look like trivial.
February 15, 2020, 17:12 |
Agustín Villa
Rep Power: 15 |
indeed, the simulation was set with a low Reynolds k-epsilon model (that is why the 100000 folder), and I reached the desired Re_tau. The first cell height has a y+=0.5. |
February 15, 2020, 17:29 |
Rep Power: 12 |
Sorry didnt get the last entry of yours.
Is the problem due to LRR or low-Re kEpsilon (exactly which kEpsilon variant in OF since "kEpsilon" is high-Re itself)? EDIT: Sorry. I dont know where LRR appeared. . I think I thought you are using a Reynolds Stress model (but eddy-viscosity model instead you used), thats why.. If you inform which kEpsilon variant you have used, it would be useful before downloading your case (no PC for few days, sorry).
Reynolds stress transport model with elliptic relaxation | xiao | OpenFOAM Running, Solving & CFD | 1 | February 15, 2020 12:06 |
Reynolds stress model | Antoni_char | STAR-CCM+ | 2 | March 27, 2017 09:11 |
Reynolds Stress Models for bluff body flows | siw | CFX | 1 | March 4, 2016 05:58 |
Overflow Error in Multiphase Modelling with Two Continuous Fluids | ashtonJ | CFX | 6 | August 11, 2014 14:32 |
Reynolds Stress Model | deeimproptus | FLUENT | 3 | November 3, 2011 03:23 |
