February 13, 2020, 05:29 |
periodic set up - cyclicAMI
Javier Vinuales
Rep Power: 9 |
Hi everyone,
I am OpenFOAM newbie, so bear with me! I am a bit confused about cyclicAMI and how to set it up... I have not been able to find some tutorials that replicate what I am trying to do. So, I am studying 3D periodic porous structures. Previously, I had access to commercial software (STAR CCM+) and I will have a set up with a single unit cell with periodic conditions in all 3 directions (in the flow direction, a special type of periodic BC which is called "fully developed flow" that allows specifying certain mass flow rate through the boundary). This set up keeps the domain (and thus cell count) very low, which is important as I have to characterize many different geometries (100-1000) every time. The objective is to replicate this set up in OpenFOAM (if possible). I was thinking cyclicAMI may be the best option, as creating periodic meshes can be challenging for complex geometries (as my case). I will be using simpleFOAM at the moment (with a modified version to account for heat transfer later on) - Is it cyclicAMI the right choice? - For the special case of the periodicity in the flow direction, can cyclicAMI be used? how can I specify certain flow through the boundary? - Once I created the mesh, I just have to modify the following files: - constant/polyMesh/boundary - 0/U , 0/p , 0/T ... Is this workflow correct? what will be correct set up in each file? Thanks! Javier |
February 13, 2020, 23:39 |
Yogesh Bapat
Rep Power: 15 |
You can use cyclicAMI. But I think translation periodic will need additional implementation. It can be either pressure gradient specification or mass flow rate specification. You can use it for rotational periodic directly.
February 14, 2020, 04:03 |
#3 | |
Rep Power: 9 |
Lets begin with some of your questions. Generally there are two main options to set periodicity. If you are able to generate a conformal mesh, cyclic would be the choice: User Guide: Cyclic In case of non conformal meshes you may choose CyclicAMI oder GGI (foam-extend): User Guide: cyclicAMI Conformal mesh means, that the nodes of the faces you want to connect are matching together perfectly. As far i know, you can't specify a flow through an cyclic/cyclicAMI interface. Its only a connection of both sides. It would be nice if you can give us a few more informations like: - which OpenFOAM version do you want to use? - how do you generate the mesh? Greetings bastian Last edited by .bastian; February 14, 2020 at 06:53. |
February 14, 2020, 06:37 |
Javier Vinuales
Rep Power: 9 |
Thank you for your answers.
I thought I would go about this step by step: - first, will try to set up cyclicAMI in the 2 directions perpendicular to the flow. - second, I will try to implement periodicity in the flow direction. The first case should be more straight-forward. I managed to set it up in 1 direction, and it ran without problems. However, the results seemed odd as not as much flow as expected was getting through the cyclicAMI boundary. Furthermore, if I added the second pair it will not run (file attached). Regarding the second case, I saw that some flow rate can be forced through the boundary with fvOptions (momentumsource:meanVelocityForce), and hopefully works well with cyclicAMI. For the pressure, I saw jumpCyclicAMI, that could work for representing a jump in pressure from inlet to outlet. However, I am not sure about other fields such temperature and turbulence variables. Javier Last edited by jvinuales; February 19, 2020 at 10:24. |
February 14, 2020, 06:46 |
#5 | |
Javier Vinuales
Rep Power: 9 |
In terms of meshing, currently using cf-mesh+ (with a trial)... also still trying to figure out what works better for me. |
February 19, 2020, 07:02 |
Javier Vinuales
Rep Power: 9 |
I made some progress with this case.
I have the periodicity in all three directions, and the case run without problems. I used cyclicAMI in all the directions, and add the following to fvOptions: Code:
momentumSource { type meanVelocityForce; selectionMode all; fields (U); Ubar (-0.6 0 0); } pRefCell 0; pRefValue 0; Is there any boundary condition I can apply for the pressure that results in a physically realistic condition? Like an undefined constant offset?? or any other set up recommendations? case: https://drive.google.com/file/d/1R85...ew?usp=sharing gyroid_p.JPG gyroid_U.JPG gyroid_U_zx.JPG |
February 20, 2020, 04:44 |
Javier Vinuales
Rep Power: 9 |
I found the fixedJumpAMI boundary condition that could be applied in the flow direction:
0/p Code:
x1 { type fixedJumpAMI; patchType cyclicAMI; jump uniform 1; value $internalField; } x2 { type fixedJumpAMI; patchType cyclicAMI; value $internalField; } Code:
x1 { type cyclicAMI; } x2 { type cyclicAMI; } Gyroid_p.JPG Gyroid_U.JPG I will start trying to set up turbulence and temperature. Regarding turbulence, can I assume that the turbulence parameters are periodic (as U)? hence I can use cyclic? |
February 23, 2020, 20:48 |
Peter Baskovich
Rep Power: 11 |
I've done a few simulations almost exactly like this meanvelocityForce is a closed loop control method that applies a pressure gradient to the flow to sustain the desired flow rate. If you watch the logs there should be a printout of the current pressure drop the solver is using.
I've found this to be the most reliable and convergent method. Especially if you want to study the flow at particular flow rates rather than applying pressure drops and hoping to find a flow rate. I used cyclic turbulence parameters and U in my study and p ends up being cyclic with a jump. T can be difficult because if it is cyclic it will blow up. Additionally, if the flow is compressible then the physical properties are dependant on T so a cyclic study is non-physical. The other way I have achieved good results is using mappedPatch. Inlet is set to mappedPatch type and condition is mapped. Turbulence is mapped from outlet to inlet, outlets are zeroGradient. U is mapped the same but with setAverage true; as is T. p is the only field that does not get mapped. outlet uses the fixedMean condition and inlet uses zeroGradient. Start the flow overdamped and then lower the damping after it's starred and you should see convergence. You may also need to extend your domain to be 2,3, or 4 repetitions of the geometry. |
February 28, 2020, 05:48 |
#9 | ||||
Javier Vinuales
Rep Power: 9 |
Thanks for your answer! It really helps.
I am not sure I fully understand what you mean with this statement? |
March 4, 2020, 02:34 |
#10 | ||
Peter Baskovich
Rep Power: 11 |
The meanVelocityForce fvOption will cause these outputs: Start of execution Code:
Creating finite volume options from "constant/fvOptions" Selecting finite volume options type meanVelocityForce Source: momentumSource - selecting all cells - selected 60000 cell(s) with volume 16 Initial pressure gradient = 0 Code:
Time = 0.8 PIMPLE: iteration 1 smoothSolver: Solving for Ux, Initial residual = 0.0112044, Final residual = 5.90986e-06, No Iterations 2 smoothSolver: Solving for Uy, Initial residual = 0.0606708, Final residual = 3.37513e-06, No Iterations 3 smoothSolver: Solving for Uz, Initial residual = 0.0579524, Final residual = 2.73287e-06, No Iterations 3 Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 2.67342e-05 GAMG: Solving for p, Initial residual = 0.13367, Final residual = 0.00203606, No Iterations 2 time step continuity errors : sum local = 1.22471e-06, global = 1.74992e-20, cumulative = -2.29145e-19 Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 2.6722e-05 GAMG: Solving for p, Initial residual = 0.0107536, Final residual = 7.18508e-07, No Iterations 5 time step continuity errors : sum local = 4.79701e-10, global = -5.57251e-20, cumulative = -2.84871e-19 Pressure gradient source: uncorrected Ubar = 0.1335, pressure gradient = 2.66637e-05 ExecutionTime = 0.52 s ClockTime = 2 s fieldAverage fieldAverage1 write: Calculating averages Courant Number mean: 0.302291 max: 0.522438 Please look at the channel395 tutorial in "openfoam/tutorials/incompressible/pimpleFoam/LES/channel395". It works just fine for RAS cases, but that tutorial just happens to be where the function is demonstrated. T can be added as a passive scalar using a function in controlDict called scalarTransport. I have a rough example but I'm not sure it works properly. Or you can duplicate the case and create a new case for the scalarTransportFoam solver to run after your original case on the frozen field. About mapped patches: Quote:
March 4, 2020, 04:22 |
#11 |
Javier Vinuales
Rep Power: 9 |
ok, I finally understand!! Thanks!!
My problem was that the pressure field is not updated... I was just checking the results with Paraview and with functions as pressureDifferencePatch and these do not reflect the pressure gradient. Is there a way to update the p field with the pressure gradient source so the results in Paraview and the postprocessing functions reflect the actual p? |
March 4, 2020, 21:42 |
#12 |
Peter Baskovich
Rep Power: 11 |
Sure you can, but not automatically without using more functions.
I do this by using the calculator function in paraview. Hit ctrl+space to bring up the filter search and look for "calculator". Grab the pressure gradient from the last iteration in your log file. Multiply the pressure gradient by the point position in the direction of your flow, for me that is the X coordinate. The gradient may need to be negative to be in the correct direction but that should be obvious. You now have a new field called realP that includes the pressure gradient. While you're in there you could also multiply by density to calculate the real static pressure instead of kinematic pressure. |
March 6, 2020, 08:59 |
#13 | |
Javier Vinuales
Rep Power: 9 |
Thanks again.
If that is the case, jumpAMI should work correctly and lay physical results, always making sure that gradT and dT (jump) are consistent with each other for the fluid properties. However, the temperature increases without control, as there is no temperature reference or any ways to specify the inlet temperature (for example). In the case of the pressure this is avoided through pRefCell and pRefValue... is there any equivalent formulation for temperature? Also, I saw the possibility to try to force the inlet average temperature to be maintained as here: Maintaining average temperature at Inlet in cyclic Boundary condition did you have any success implementing this option? |
March 13, 2020, 22:19 |
fully developed pipe flow in LES
#14 |
bany
Rep Power: 7 |
Hi, peter, i am interested in your method. But when using these in a pipe to get a fully developed pipe flow, i am always failed.
For your mapped method, did you add a initial perturbation to the flow field such as turbulentInlet or other? Because i found if there is no initial perturbation , it is difficult to produce a fully developed pipe flow. And for my case with a pipe of 20D length, U is mapped with setAverage ture (110 0 0). k is also mapped with setAverage no. p and nut is not mapped. After about 100 flow times, i cannot see a fully developed flow structure and the Umean is gradually increasing. By the way, i found add a wallFunction to nut only change the U profile near the wall having few effect on the entire U proflie. |
April 21, 2020, 21:47 |
#15 |
Peter Baskovich
Rep Power: 11 |
Hi bany,
Sorry for the delayed reply. What are your pressure conditions? Also every quantity except for pressure should be mapped, this includes the turbulent fields. I have not used many LES simulations but from my understanding LES is much more sensitive to initial conditions than RAS. Obviously in a periodic flow we should see convergence to the same solution over a wide range of initial conditions. I think you are right to try and introduce some initial perturbations. |
April 21, 2020, 22:20 |
#16 | |
bany
Rep Power: 7 |
April 22, 2020, 03:50 |
#17 |
Peter Baskovich
Rep Power: 11 |
Your zip file is broken, do you want to try again?
April 22, 2020, 06:57 |
#18 |
bany
Rep Power: 7 |
OK.
The y+~5, and the solver pisoFoam is used. Much thanks! |
April 24, 2020, 03:47 |
#19 |
Peter Baskovich
Rep Power: 11 |
Is this not what you are expecting?
I changed a few things: Pipe made shorter Mapping taken from exit patch instead of offset Mapped nut also p field uses fixedFluxPressure (probably has no effect in this context) Have a look at how blockMeshDict is defined for the patches Added minIter 1 to U and p solutions I had to turn some of your functions off to get it to run but shouldn't effect solution. See attached pipe-mapped-short2.zip |
April 24, 2020, 07:23 |
#20 | |
bany
Rep Power: 7 |
cyclic, cyclic ami, cyclicami, periodic bc |
[ANSYS Meshing] Solution to periodic boundary problem | SophieLee | ANSYS Meshing & Geometry | 1 | June 28, 2017 01:51 |
cyclicAMI and interDyMFoam for periodic box | kwardle | OpenFOAM | 1 | March 11, 2014 13:40 |
correction of Grub after installing Windows XP and 8 | immortality | Lounge | 20 | January 5, 2014 17:41 |
How to set periodic boundaries with initial conditions? | jiandai | OpenFOAM | 6 | October 24, 2013 07:00 |
[snappyHexMesh] determining displacement for added points | CFDnewbie147 | OpenFOAM Meshing & Mesh Conversion | 1 | October 22, 2013 09:53 |
