Issue Installing Paraview for OpenFOAM
Old   February 14, 2020, 22:20
Default Issue Installing Paraview for OpenFOAM
anonymous
felik9 is on a distinguished road
I am trying to install Paraview that's required for OpenFOAM according to the instruction provided in this link:
https://www.openfoam.com/download/install-source.php
However, I get an error when I enter the following prompt:
root@nanay001-Bonobo-WS:/home/nanay001/OpenFOAM/ThirdParty-v1912# ./makeParaView
./makeParaView: 64: local: -DWM_DP: bad variable name
./makeParaView: 64: ./makeParaView: -DOPENFOAM: bad variable name
The error message is the last two lines above.
Please advise.
felik9 is offline   Reply With Quote
Old   February 15, 2020, 04:15
HPE
Herpes Free Engineer
HPE is on a distinguished road
Please find the related threads in OF-GitLab and StackExchange. It is a solved problem:
https://stackoverflow.com/questions/...43244#59643244
https://develop.openfoam.com/Develop...am/issues/1541
https://develop.openfoam.com/Develop...mmon/issues/48
Kind regards,
HPE
The OpenFOAM community is the biggest contributor to OpenFOAM; not person A or B. Let's report bugs or issue feature requests in GitLab-OpenFOAM.
Please `design` your questions well. Such effort always pays off well for inquirers and `helpmate`s:
How to create a Minimal, Reproducible Example,
How to give enough info to get help.
HPE is offline   Reply With Quote
Old   February 15, 2020, 05:41
Mary
MariMari is on a distinguished road
Hi
I read your post.
thank you very much.
Good luck
Download a beautiful song by Farzad Farzin
MariMari is offline   Reply With Quote
Old   February 16, 2020, 01:28
anonymous
Hi
I've followed the solution as posted in the 3 links provided above. However, I am still getting error messages. This is what I have done:
1- Edit the ./cmakeParaView file to change the first line from #!/bin/sh to #!/bin/bash
2- run the command: sudo dpkg-reconfigure dash
When I run the above command, I get the message prompt shown in the attached file, or below, which I select "NO":
Configuring dash
The system shell is the default command interpreter for shell scripts.
Using dash as the system shell will improve the system's overall
performance. It does not alter the shell presented to interactive users.
Use dash as the default system shell (/bin/sh)?
<Yes> <No>
3- run the command: ./makeParaView
At the end of this run, I get the following error output:
-- Looking for IceConnectionNumber in ICE
-- Looking for IceConnectionNumber in ICE - found
-- Found X11: /usr/lib/x86_64-linux-gnu/libX11.so
CMake Error at VTK/CMake/vtkQt.cmake:6 (message):
Expected value for VTK_QT_VERSION is '5'
Call Stack (most recent call first):
VTK/GUISupport/Qt/CMakeLists.txt:1 (include)
-- Configuring incomplete, errors occurred!
See also "/home/nanay001/OpenFOAM/ThirdParty-v1912/build/linux64Gcc/ParaView-5.6.3/CMakeFiles/CMakeOutput.log".
See also "/home/nanay001/OpenFOAM/ThirdParty-v1912/build/linux64Gcc/ParaView-5.6.3/CMakeFiles/CMakeError.log".
I am not sure how to fix this error, please advise.
Thanks
Old   February 16, 2020, 07:05
HPE
It seems you solved the first problem. This is another problem. Have you installed all required pre-requisite packages? e.g. package for VTK?
Kind regards,
HPE
Old   February 16, 2020, 23:53
anonymous
I recently installed VTK 8.2, but I'm still getting the same error as shown below.
I am not sure what else I could do to fix this problem. I have attached a file with the complete run that I obtained. Please advise.
Old   February 17, 2020, 16:31
HPE
Build ParaView separately?
Almost always ParaView is pain in the arse for OpenFOAM maintainers for various legitimate reasons.
I never bother with paraFoam. Using ParaView directly is possible, so. e.g. In your simulation directory you create an empty text file, like with a name a.foam, and just calling "paraview a.foam" is equivalent to "paraFoam", alomost.
In the worst case, you can submit a bug ticket in GitLab.
Kind regards,
HPE
[foam-extend.org] foam-extend-3.1 multiple versions paraview issue CFDpal OpenFOAM Installation 1 May 31, 2018 09:51
[General] Paraview display issue on Windows zjx1805 ParaView 0 May 4, 2018 14:06
Issue installing SU2-AD kaush SU2 1 April 23, 2018 11:40
[OpenFOAM.org] problem installing ParaView with openFoam5 enginpower OpenFOAM Installation 3 March 26, 2018 11:34
Installing OpenFOAM without Paraview quartzian OpenFOAM Installation 0 September 8, 2008 10:29
