How to recompile OpenFoam: Allwmake error
Hi everyone,
I need to recompile OpenFoam but trying to run Allwmake I got this error: asus@asus-K53SV:/opt/openfoam5$ ./Allwmake Allwmake /opt/openfoam5 ./Allwmake: 22: ./Allwmake: make: not found asus@asus-K53SV:/opt/openfoam5$ Can anyone explain me how to use, step by step, Allwmake? Thank you so much. |
https://www.cfd-online.com/Forums/op...d-mhdfoam.html
Well, It can be little confusing because I wasn't even sure wheter I was using 18.06 or OF6 back than. But this thread will help you. thanks to Dr. Teschner I was able to pull it off. |
wmake utility is a (let's call it this way) wrapper around GNU make utility. So error Code:
./Allwmake: 22: ./Allwmake: make: not found Code:
sudo apt install make Quote:
