Particle-tracking coupling with other cases.
4 Attachment(s)
Hi everyone,
Firstly, if this is an unnecessary question sorry for this. I did solve a case with using PISO algorithm similar to pitzDaily file. I did LES simulation now I want to take it to the next level with particle-tracking. You can see what I've done at the attachment. I just want to a few particle goes to the volume of my geometry with inlet (at the bottom) and flow to the outlet (at the top). I looked for a tutorial case like this but I couldn't find anything. Is there a way to couple my case with particle-tracking cases? I am open to any advice (or source). By the way, I'm adding my files and some screenshots in case you want to know. Best regards, Said. |
You can use icoUncoupledParcelFoam to solve particles with obtained flow field.
Hi ybapat,
I tried icoUncoupledParcelFoam to ran my own case and it worked just fine. As you see in the attachment I did enter the 11 particle's position with my hands. But I want to the particles to enter the system on their own, without entering their position. How can i do this? And I wonder, is there a way to see where these particles accumulate in the system? Note: I tried with simpleFoam pitzDaily case, not LES. Gif: https://gfycat.com/filthyhardibadanmalimbe Best regards, Said. |
You can try different types of injections available.
Hi again ybapat,
I ran the simulation by injection (patchInjection). But there is a problem. After a while, the cycle stops working before completion. Why is this happening? What should I do? kinematicCloudProperties Code:
/*--------------------------------*- C++ -*----------------------------------*\ It looks like this. Code:
Time = 0.29 Gifs: https://gfycat.com/revolvingoldfashionedindigobunting https://gfycat.com/poshfarhoatzin |
Hi everyone,
I think i did solve my problem. I just reduced the parcelsPerSecond and increased the duration. Gif: 1) https://gfycat.com/energeticdecisivecurlew 2) https://gfycat.com/admirablemadaruanas Code:
injectionModels Said. |
