SIMPLE relaxationFactors nomenclature ".*"
Like Tree1Likes
  • 1 Post By tas38
Old   April 1, 2020, 05:53
Default SIMPLE relaxationFactors nomenclature ".*"
Tobermory will become famous soon enough
A trivial question, but I could not find any reference to this online. The relaxationFactors subdictionary of fvSolution for one of the SIMPLE solver tutorial cases reads as follows:
relaxationFactors
equations
U 0.9;
".*" 0.9;
This clearly sets the factor for the U equations (first line) and all the other variables (second line). In the OpenFoam User Guide, I have seen:
equations
U 0.7;
"(k|omega|epsilon).*" 0.7;
Can anyone please explain the terminology here? What is the .* referring to? I can see how to use it, but I'd like to know what it means, rather than it being a black box. Many thanks.
Tobermory is offline   Reply With Quote
Old   April 3, 2020, 12:27
Ok - solved. Section 4.2.12 of the User Guide talks about Regular Expressions, of which this is an example.
Old   April 3, 2020, 22:54
Troy Snyder
tas38 is on a distinguished road
As you mentioned. This is detailed with the OF user guide. But for those who future reference this forum entry, here is the explanation (taken directly from OF user guide v7)...
"inlet.*" matches any word beginning inlet. . . , including inlet itself, because ‘.’
denotes “any character” and ‘*’ denotes “repeated any number of times, including 0
times”.
"(inlet|output)" matches inlet and outlet because () specified an expression
grouping and | is an OR operator.
Tobermory likes this.
tas38 is offline   Reply With Quote
Old   April 4, 2020, 09:33
Thanks, Troy. The one that had me scratching my head was ".*" ... I was wondering: why not just "*". But that's not the way the regexp language works. As you point out, the "." means any character (including an empty space, but not endline) and the "*" means repeated any number of times (including zero times).
I suggest reading up the page on wikipedia: it's pretty informative.
https://en.wikipedia.org/wiki/Regular_expression
Continuity divergence in simple gas flow Okka FLUENT 7 January 11, 2019 01:01
Simple loop in LaplacianFoam Houthuys OpenFOAM Programming & Development 1 January 24, 2017 03:18
SIMPLE vs. PISO Kappa OpenFOAM Running, Solving & CFD 1 October 17, 2016 08:08
Simple doesn't stop after convergence criteria is achieved thiagopl OpenFOAM Running, Solving & CFD 3 April 2, 2015 10:29
SIMPLE algorithm Jonathan Castro Main CFD Forum 3 December 10, 1999 04:59
